vtec/vafc question
Old Apr 14, 2004 | 05:32 PM
blackb18c1eg's Avatar
Default vtec/vafc question
I have an eg with a gsr in it, I recently put in a vafc and since then whenever i am in 4th gear vtec wil not turn on and i get a check engine light for the vtec solenoid. I have not touched the settings on the vafc yet and vtec works fine in 1st thru 3rd. has anyone ever heard of this before, any help is much appreciated.
Old Apr 14, 2004 | 05:45 PM
X2BOARD's Avatar
Default Re: vtec/vafc question (blackb18c1eg)
Assuming it's installed correctly... did you perform the initialization procedure stated in the manual ?
Old Apr 14, 2004 | 06:49 PM
Syner-G-Racing LLC's Avatar
Default Re: vtec/vafc question (X2BOARD)
just as it was previously stated, their are different types of v tec's low, medium and high rpm levels.
Old Apr 14, 2004 | 08:06 PM
X2BOARD's Avatar
Default Re: vtec/vafc question (Syner-G-Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing &raquo;</TD></TR><TR><TD CLASS="quote">just as it was previously stated, their are different types of v tec's low, medium and high rpm levels. </TD></TR></TABLE>
What ??????
Old Apr 14, 2004 | 08:08 PM
krazie1's Avatar
BANNED
for the vafc I think he means??
Hope so if not I am also stumped with this quote
Old Apr 14, 2004 | 08:18 PM
X2BOARD's Avatar
Default Re: vtec/vafc question (krazie1)
But the AFC only has low and high throttle points....
Old Apr 15, 2004 | 02:10 AM
92b16vx's Avatar
Did you hook up the VTM wire? Did you set it up to run with your motor, doesn't have to be tuned, but it has to be set to the correct # of cylinders, sensors, etc...
Old Apr 15, 2004 | 05:17 AM
X2BOARD's Avatar
Default Re: (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx &raquo;</TD></TR><TR><TD CLASS="quote">Did you hook up the VTM wire? Did you set it up to run with your motor, doesn't have to be tuned, but it has to be set to the correct # of cylinders, sensors, etc...</TD></TR></TABLE>
ya....that's the initialization procedure....
Old Apr 15, 2004 | 05:42 AM
92b16vx's Avatar
Default Re: (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">
Yea, but the intialize function in the miscellanous section resets it to factory settings.
Old Apr 15, 2004 | 07:20 AM
X2BOARD's Avatar
Well... I didn't mean the initialization function... I mean the procedure as spelled out in the manual... involves throttle type, cylinders, sensor test..etc...
dx2sicrx
Engine Management and Tuning
May 19, 2008 10:21 AM
98 blacksh
Feb 17, 2005 02:23 PM
HYREV2NR
Jul 24, 2003 07:56 AM
honda8882
Jul 23, 2003 11:27 AM
fxrob
Jun 12, 2003 08:59 PM
