ls block with b16 rods and ls pistons= low compression?
Old Apr 13, 2004 | 07:34 PM
ensracer's Avatar
Default ls block with b16 rods and ls pistons= low compression?
pretty much asking what kind of a result i will get if i put b16 rods in an ls block...
Old Apr 13, 2004 | 10:59 PM
mmuller's Avatar
Mad Scientist
Default Re: ls block with b16 rods and ls pistons= low compression? (eduardo)
lol, yeah i gues you could say that.
b16 rod=134mm
b18a/b rod=137mm
compression would be about 7.4...ouch
Old Apr 14, 2004 | 07:07 PM
zensoku207's Avatar
Turbo it and run 50 psi.....
Old Apr 14, 2004 | 07:42 PM
turboant's Avatar
Default Re: ls block with b16 rods and ls pistons= low compression? (mmuller)
no it wouldnt be that low im doing some like that but im using the b16 eagle rod 8:5.1 srp piston but it a lsvtec turbo
Old Apr 14, 2004 | 07:44 PM
zensoku207's Avatar
b16 rods are too short for LS block/crank, they wont reach the top of the block.....definite dampener on the ol CR.
Old Apr 14, 2004 | 07:45 PM
mmuller's Avatar
Mad Scientist
Default Re: ls block with b16 rods and ls pistons= low compression? (turboant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboant &raquo;</TD></TR><TR><TD CLASS="quote">no it wouldnt be that low im doing some like that but im using the b16 eagle rod 8:5.1 srp piston but it a lsvtec turbo </TD></TR></TABLE>
yes it would....do the math...
3mm difference in compression height
CTR_B
Oct 17, 2008 04:19 PM
mrbsponge
Apr 28, 2005 08:01 PM
hOndafienD 04
Apr 6, 2005 08:42 PM
hOndafienD 04
Feb 10, 2005 04:00 AM
Krussty420
Sep 27, 2004 11:29 PM
