B16a Timing Belt
Old Apr 17, 2004 | 04:50 PM
evad's Avatar
Default B16a Timing Belt
I am doing a JDM B16a swap into my 91 hatch and want to know what timing belt to use? I got a timing belt for a 1.6 DOHC B series motor from honda but it has 125 teeth on it and the one that came on the motor has 124. Will that extra tooth throw off the cam timing? If so what year, make, and model should I order a timing belt from? Of coarse the Honda dealership here doesn't know what I'm talking about!
Old Apr 17, 2004 | 05:09 PM
mmuller's Avatar
Mad Scientist
Default Re: B16a Timing Belt (91 JDM Hatch)
are you sure you counted the teeth right?or did you get the right timing belt?
cause i've never seen that, all b16 timing belts are the same
Old Apr 18, 2004 | 09:01 AM
evad's Avatar
Default Re: B16a Timing Belt (mmuller)
Well i put a twistie tie on the belt where i started so i knew where to end. And then i noticed that they are marked on the belt with how many teeth there are. So what should i order the belt for? 00 Si, Del Sol Vtec, or does it matter?
Old Apr 18, 2004 | 12:35 PM
DragII's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91 JDM Hatch &raquo;</TD></TR><TR><TD CLASS="quote"> So what should i order the belt for? 00 Si, Del Sol Vtec, or does it matter?</TD></TR></TABLE>
doesn't matter, they are all the same
Old Apr 18, 2004 | 02:15 PM
func-tion's Avatar
Default Re: B16a Timing Belt (DragII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragII &raquo;</TD></TR><TR><TD CLASS="quote">
doesn't matter, they are all the same</TD></TR></TABLE>
And even if it did have extra teeth it wouldint matter unless it slipped.
imadigitalgod
Aug 18, 2023 08:01 PM
07pilot
Engine Management and Tuning
Nov 2, 2011 05:41 PM
patwitahonda
Oct 19, 2009 11:11 AM
BuiltCivic99
Aug 24, 2009 12:14 PM
Jeffrey9
11
Aug 6, 2008 08:56 PM
