Snap ring came off the axle while it was in the tranny.... HELP!
Old Apr 14, 2004 | 03:36 PM
Blaze45's Avatar
Brrraaaap!
Default Snap ring came off the axle while it was in the tranny.... HELP!
Yeah just like the stupid topic says, Im a complete idiot. It all started when I changed the axle out, the seal started leaking. So I got a new seal. Then the axle would pop out. I had read on HT that some people had bent the snap ring on then end of the axle to keep the axle seated properly. Instead of following a wise HTers advice and getting a new snap ring I thought what the heck, why not give it a shot? Well, turns out I bent it to much cause the axle would still slide around, so I pulled the axle out and the snap ring was gone. God hlep me, I am ready to blow my car up. Any advice would be great, accept the obvious. (taking the tranny out and apart and getting it out...)
tia
Blaze
Old Apr 14, 2004 | 03:39 PM
rxse7n
Guest
Posts: n/a
Can you see it stuck in there at all? It may be stuck in the groove in there and you might be able to get it with some long, thin pliers. If not, you are gonna be takin apart your tranny. I don't know any other way...maybe someone else will.
Old Apr 14, 2004 | 03:50 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (rxse7n)
I cant see the ring at all.... I tried fishin around with a small hook.... maybe it went to the bottom and I could somehow get it out through the drain hole? I doubt it.....
omg Im shaking Im so mad at myself..
Blaze
Old Apr 14, 2004 | 05:56 PM
BeerMan's Avatar
Default Re: (Blaze45)
oh man, i hate that feeling
do you have access to a magnet?
Old Apr 14, 2004 | 07:41 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (BeerMan)
I was thinking possibly a flexible manget that I could fish down there... Anyone else have an idea???
tia
Blaze
Old Apr 14, 2004 | 07:43 PM
LudeyKrus's Avatar
Go to Autozone and buy the $.99 telescoping magnet and stick it in and start wiggling around.
With some luck, it will catch the ring and you can pull it out.
Old Apr 14, 2004 | 08:24 PM
Finger Lickin' good's Avatar
Default Re: (LudeyKrus)
Im sorry man. I get 5 posts a day and you get one. When things go right, you love your car. When things go bad you hate your car. Ill smoke you a fat bowl. It sucks, its like you wanna fix something simple like put an intake on, and you break you TB. Thats something I would do, dont ask, im just a noob witha doob. I hope that wasnt your daily driver.
Old Apr 19, 2004 | 06:40 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (...1STP KLOSER...)
Does anyone know where to get a really thin flexible magnet from?
tia
Blaze
Old Apr 19, 2004 | 06:55 PM
showbiz's Avatar
drain your fluid, see if it fell to the bottom, definatly use a magnet, I don't know if this would work but try to glue/bond/weld a small magnet to some solder wire so you can bend it around, just make shure the magnet will not fall off inside !!
Old Apr 19, 2004 | 08:08 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (sedanman)
I did drain everything, the drain hole is too small to fit a mangent through... and so is the filler hole...... I have got to find a long skinny/thin magnet...
Blaze
Old Apr 19, 2004 | 08:31 PM
foxfai's Avatar
Go to some of those new gaget stores like brookstone,discovery or even radioshack. I've seen the rare magnets that are like a small battery cell and very strong. Hope this helps.
Old Apr 19, 2004 | 08:51 PM
Grey_DA93's Avatar
Default Re: Snap ring came off the axle while it was in the tranny.... HELP! (Blaze45)
use my favorite tool, a BFH!!! ( big freakin Hammer ) BEAT THE TRANNY TILL IT FALLS OUT...you might also try flushing out the tranny with some fluid...it might push out the ring...
Old Apr 20, 2004 | 02:14 AM
OTT's Avatar
OTT
Blaze, chillout, take things step by step.
If you can gethold of a diargram of the Transmission then you can predict the most likely place it has gone (what with this Gravity thing N'all )
Then use a thin magnet and go fisshing for it
Old Apr 20, 2004 | 03:35 AM
bradford's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ...1STP KLOSER... &raquo;</TD></TR><TR><TD CLASS="quote">Im sorry man. I get 5 posts a day and you get one. When things go right, you love your car. When things go bad you hate your car. Ill smoke you a fat bowl. It sucks, its like you wanna fix something simple like put an intake on, and you break you TB. Thats something I would do, dont ask, im just a noob witha doob. I hope that wasnt your daily driver. </TD></TR></TABLE>
Yes i will also smoke a bowl to this, and maybe another, because today it the great day of April 20, good luck with your trans.peace, lawdamercy
fin781
Aug 15, 2012 06:22 PM
AnotherEJ
Dec 10, 2008 05:16 PM
xingyun
Nov 30, 2008 02:06 PM
krazycivic
Dec 11, 2002 10:02 PM
StockTeg
Jul 30, 2002 01:20 PM
