Socketing a JDM p30 for Uberdata
Old Apr 15, 2004 | 06:20 PM
EGhatched's Avatar
Default Socketing a JDM p30 for Uberdata
I got a JDM p30 with my JDM swapped b16, lol that makes sense. I want to try out Uberdata. Can i chip my p30? I ordered all the parts from the parts list i found at this site:
http://home.mn.rr.com/keebler6....html
Will these only work for the p28?
thanks
andrew
Old Apr 15, 2004 | 08:43 PM
Joseph Davis's Avatar
Default Re: Socketing a JDM p30 for Uberdata (EGhatched)
A GayDM P30 uses a surface mount 74HC373, which is not at all the same as the normal 20-DIP used in USDM ECUs. The correct part is listed on pgmfi.org's wiki - where you should go for authoratative information on Honda ECU chipping (no offense to keebler, he's got a good primer) .
I recommend holding the SMT 74HC373 to the ecu with a drop of glue so that you don't slide the tiny thing all over the place trying to get it soldered. Use a 15 watt iron with a very tiny tip and steady your hands as best you can. I don't bother adding more solder, that only gets things messy IME.
Old Apr 15, 2004 | 11:21 PM
hndarcrb18c1's Avatar
Default Re: Socketing a JDM p30 for Uberdata (J. Davis)
Or he can hope and pray its a Automatic P30 wich is pre socketed from Honda......
Old Apr 16, 2004 | 08:38 AM
EGhatched's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">A GayDM P30 uses a surface mount 74HC373, which is not at all the same as the normal 20-DIP used in USDM ECUs. The correct part is listed on pgmfi.org's wiki - where you should go for authoratative information on Honda ECU chipping (no offense to keebler, he's got a good primer) .
I recommend holding the SMT 74HC373 to the ecu with a drop of glue so that you don't slide the tiny thing all over the place trying to get it soldered. Use a 15 watt iron with a very tiny tip and steady your hands as best you can. I don't bother adding more solder, that only gets things messy IME.</TD></TR></TABLE>
well ****, I wont even bother with the GayDM p30. I"ll just keep it as a failsafe incase i have problems with the p28 that i'm getting. So everything that i ordered from Keeblers parts list will work good with my p28?
Old Apr 16, 2004 | 09:44 AM
Yup yup. Feel free to PM me if you have any Q's or last minute problems... keebler, and a dozen others, would probably be happy to help you with that sort of thing, too.
Old Apr 16, 2004 | 10:47 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Use a 15 watt iron with a very tiny tip</TD></TR></TABLE>
So thats why my soldering didnt work when I played with it.. Im using a 40 watt iron..
Old Apr 16, 2004 | 11:53 AM
EGhatched's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Yup yup. Feel free to PM me if you have any Q's or last minute problems... keebler, and a dozen others, would probably be happy to help you with that sort of thing, too.</TD></TR></TABLE>
does keebler have a honda-tech name?
is so could you hook a fellow honda friend up
Old Apr 16, 2004 | 04:02 PM
Jim Truett's Avatar
Default Re: Socketing a JDM p30 for Uberdata (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
So thats why my soldering didnt work when I played with it.. Im using a 40 watt iron.. </TD></TR></TABLE>
The 15 watt iron is to keep you from overheating the SMD 74HC373. I recommend a 35-40 watt iron for the through-hole components.
Old Apr 16, 2004 | 04:03 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatched &raquo;</TD></TR><TR><TD CLASS="quote">
is so could you hook a fellow honda friend up</TD></TR></TABLE>
I could probably help you. I have a shitload of the parts needed to chip an ECU sitting in my garage. Let me know what you need.
Old Apr 16, 2004 | 06:53 PM
baphomet's Avatar
Default Re: Socketing a JDM p30 for Uberdata (Jim Truett)
My $6 pos radio shack iron works too
Old Apr 20, 2004 | 11:37 PM
infra's Avatar
Default Re: Socketing a JDM p30 for Uberdata (devnull)
anyone knows if the p30 jdm ecu are different from the edm p30?
PHEDROTTO
Engine Management and Tuning
Feb 4, 2011 09:33 AM
FOMULA91
Apr 17, 2009 12:57 AM
absolut b18
Jun 20, 2003 03:29 PM
43MA
Dec 19, 2002 09:51 AM
