troubleshooting injectors
Old Apr 17, 2004 | 08:45 PM
b18c1civic95's Avatar
Default troubleshooting injectors
nevermind about the resistor question I finally came to realize the fact that its just making the injectors an impedance that an ecu using saturated would want. so i should be able to use the p72 on the h22 just to see if my other ecu is bad with no problem right?? as long as the resistor box is intact.
Modified by b18c1civic95 at 12:37 PM 4/20/2004
Old Apr 19, 2004 | 04:32 AM
Default Re: troubleshooting injectors (b18c1civic95)
TtT
Old Apr 20, 2004 | 11:27 AM
first of all the ecu calls for like a total of 10 ohms right?? so if i checked the injectors individually and they came up like 2.5/piece would that mean that i might not need the resistor box. any jdm motors come setup like this. i mean the car originally started and ran fine but theres like hella gas in the oil now and it runs reallly shitty. so im trying to figure out whats going on. my timing seems fine except for the ignition timing which is kinda hard to fix when the ******* car wont run right. sorry im pissed. I've checked all i know how to check. im ready to take the whole fuel rail off and watch them spray!!!!! compression was 160 across with like 4 or 5 cranks. i guess i should do a leakdown test.
Old Apr 21, 2004 | 11:58 AM
bump
H22 SL33P3R
Nov 4, 2014 10:52 AM
crawlin
Aug 6, 2007 10:29 AM
EKHWhat
Feb 2, 2007 05:38 PM
1RMDave
Jul 22, 2004 08:00 PM
