i need help with my flywheel/clutch
Old Apr 14, 2004 | 10:57 AM
dannydos's Avatar
Default i need help with my flywheel/clutch
well i installed a new flywheel and clutch...it's my first time doing a job like this....the install was on a b18b which was an auto at one time....so the problem that i'm having now is that the crankshaft won't move at all...my starter is hot to the touch after trying to start...is it possible that i could've install my flywheel or clutch backwards...it's a fidenza flywheel and a ebay clutch stage 1...any help
Old Apr 14, 2004 | 10:59 AM
MightyMouseTech's Avatar
Default Re: i need help with my flywheel/clutch (dannydos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannydos &raquo;</TD></TR><TR><TD CLASS="quote">a ebay clutch stage 1...any help</TD></TR></TABLE>
Uh-Oh....
Old Apr 14, 2004 | 11:05 AM
dannydos's Avatar
Default Re: i need help with my flywheel/clutch (MightyMouseTech)
yeah it's a proclutch money was tight at the time... it seem like the clutch housing is hitting the tranny
Modified by dannydos at 7:00 PM 4/14/2004
Old Apr 14, 2004 | 12:35 PM
Kal's Avatar
Kal
try reinstalling it. if it doesn't work get a new clutch.. ebay clutches sucks
Old Apr 14, 2004 | 03:00 PM
dannydos's Avatar
Default Re: i need help with my flywheel/clutch (Kal)
is it possible to install the fidanza flywheel backwards....i dont think it's possible but just wondering..
Old Apr 14, 2004 | 05:07 PM
If you pull out the starter, can you turn the flywheel (by the crank pulley which is easier)?
Old Apr 14, 2004 | 05:29 PM
dannydos's Avatar
no the flywheel doesn' move at all.....and if i a 19mm socket on the crank pulley to try to turn it the bolt loosen up...the flywheel or clutch is hitting the housing...i'm pulling the whole motor out this weekend...
Old Apr 15, 2004 | 08:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannydos &raquo;</TD></TR><TR><TD CLASS="quote">no the flywheel doesn' move at all.....and if i a 19mm socket on the crank pulley to try to turn it the bolt loosen up...the flywheel or clutch is hitting the housing...i'm pulling the whole motor out this weekend...</TD></TR></TABLE>
And torque the crank pulley bolt to the right spec while you are at it [shakes head]
Old Apr 15, 2004 | 05:41 PM
dannydos's Avatar
well i pulled the motor out today after work with a friend....and what we found was that their was a huge washer that goes in between the motor and the flywheel....but that piece doesn't go there...the old tranny on this motor was a auto and i now it's a 5spd....but all is good now it's cranks over ....bit i have some bugs to strigthen out...thanks for looking at my thread...
bank2me
Jun 5, 2011 02:13 PM
VTecLude1994
Nov 7, 2008 07:12 PM
cdnB18C1
Feb 25, 2006 11:08 AM
redDAinteg
May 2, 2005 02:40 PM
H22A EG6
Nov 13, 2003 05:00 AM
