Transmission issue.....
Old Apr 13, 2004 | 05:21 PM
Slvr_CRX's Avatar
Default Transmission issue.....
Ok Here goes. After installing the shift linkage to the car, I started the car to see if i could switch gears and to see if I had the clutch cable installed properly. Well I can shift into all gears except reverse. And It doesn't matter if I have the clutch pressed or not. I even took the clutch cable off to see if i could still shift gears while the car was started and I can. And i also noticed that every time i put it into gear the speed needle moves up 5 so like from 5 to 10 to 15...... each gear it goes up 5 mph. There are no axles in the car its on jack stands. Not sure if thats the reason. Dose anyone have a clue why I am able to shift gears with the clutch not pressed? Did i install the clutch wrong. Thanks for your help. I read this link but it dose not sound like the same problem i'm going through https://honda-tech.com/zero...age=1 and also if i'm in gear the car dose not stall. so its like the clutch is pressed all the time but its not. And oh yeah I have a b16a in a crx hf 91.
Old Apr 14, 2004 | 07:41 AM
Slvr_CRX's Avatar
Default Re: Transmission issue..... (Slvr_CRX)
do you guys think i have to align it up? by driving it?
Old Apr 14, 2004 | 07:56 AM
JimBlake's Avatar
When there's no axles installed, the synchros have plenty of force to get the differential spinning. That's not unusual. After you put the axles & wheels on it won't be like that any more.
The real question is... Without axles installed, how do you keep tranny oil from pouring out the hole where the axle goes??
Old Apr 14, 2004 | 08:03 AM
d00kee's Avatar
u fingured out a *new* way to power shift! good for you, umm i dont know wut the problem is my friends sisters LS does the same thing but i think shes got the hydro tranny, we havnt really F*ed with it cuz the cars busted anyway and we dont feel like waisting the time on it cuz if its not one thing its gotta be another ya know.
Old Apr 14, 2004 | 09:08 AM
Sliced Beard's Avatar
Default Re: Transmission issue..... (d00kee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d00kee &raquo;</TD></TR><TR><TD CLASS="quote">u fingured out a *new* way to power shift! good for you, umm i dont know wut the problem is my friends sisters LS does the same thing but i think shes got the hydro tranny, we havnt really F*ed with it cuz the cars busted anyway and we dont feel like waisting the time on it cuz if its not one thing its gotta be another ya know.</TD></TR></TABLE>
dude, just no
like said before there is not much force for your internals to have ot work against
the reason why you are seeing a speed is because the VSS(vehicle speed sensor) is geared off of your differential, and since there is hardly any mass the diff spins freely thus creating a speed reading on your speedo
also if you are letting your tranny internals shift and rotate without proper lubrication you may have just ruined your tranny. You should NEVER let the tranny internals mesh and spin at high RPM's without lubrication.
Old Apr 14, 2004 | 09:45 AM
mmuller's Avatar
Mad Scientist
Default Re: Transmission issue..... (dirtyd463)
letting the tranny run with no oil....(shakes head)
Old Apr 14, 2004 | 09:49 AM
HT Chaplain's Avatar
Loved
Default Re: Transmission issue..... (JimBlake)
[/QUOTE]
speechless
Old Apr 14, 2004 | 10:07 AM
JimBlake's Avatar
Default Re: Transmission issue..... (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">letting the tranny run with no oil....(shakes head)</TD></TR></TABLE>Yeah, that's what I was afraid of.
Old Apr 14, 2004 | 10:08 AM
Slvr_CRX's Avatar
It has oil in it? i put 4 bottles worth. And its not leaking.
Old Apr 14, 2004 | 10:16 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slvr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">It has oil in it? i put 4 bottles worth. And its not leaking.</TD></TR></TABLE>Good! I thought it would have drained out thru the holes where the axles go.
Old Apr 14, 2004 | 02:57 PM
Slvr_CRX's Avatar
Ok I got in my car today and i took it for a "test drive" when i shift it into gear and press the gas it goes up like i'm driving. in every gear but i cant get into reverse and the car still dosnt stall when i let the clutch go while the car is started and in gear. Is this a good thing or bad thing.
Old Apr 14, 2004 | 05:08 PM
Slvr_CRX's Avatar
Ok If i press the clutch allllllllllllllllllll the way i can go into reverse while the car is started.
Old Apr 14, 2004 | 06:56 PM
Syner-G-Racing LLC's Avatar
sounds like its not releasing fully...allowing you to be able to drop the clutch without stalling and not engaging fully to allow you in reverse. try adjusting your cable setup.
Old Apr 15, 2004 | 05:31 AM
Slvr_CRX's Avatar
Default Re: Transmission issue..... (Syner-G-Racing)
I was thinkin that was it to but when i took the clutch cable off and let the shift lever down.(the thing that the end of the clutch cable is hooked to near the tranny) I can still shift gears with out holding the clutch down. except for reverse. Now becuase the lever is all the way down i shouldnt be able to shift gear's while the car is started right? I mean it has no axles so i am not sure if that has something to do with it.
Old Apr 15, 2004 | 06:38 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slvr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">... I mean it has no axles so i am not sure if that has something to do with it.</TD></TR></TABLE>Having no axles installed has EVERYTHING to do with that. When you shift gears, the synchro can easily get the differential spinning. If your axles were installed but the wheels were off the ground, it might even have enough force to get the tire spinning. But it sure won't work with the wheels on the ground... Don't get confused by what it can & can't do without axles.
static-x
Jul 31, 2007 09:52 AM
Condor018
Oct 19, 2006 10:07 PM
vietnamese0utlawz
Oct 5, 2006 08:38 AM
lokodog
Dec 25, 2005 09:39 PM
JDMlyfestyle
21
Sep 24, 2004 02:08 PM
