Head gasket changed - results
Old Apr 15, 2004 | 10:05 PM
petrv's Avatar
Default Head gasket changed - results
So, I finally changed my head gasket yeasterday (I needed to change it because of some overheating problems - read here https://honda-tech.com/zerothread?id=826260).
Installation was easy and without any problems, no leaks etc. The OEM gasket looks more quality than my previous aftermarket one.
I have some questions:
1) When should I top coolant in the radiator - with engine cold or hot? With engine running or stop?
2) Should the cooling system be little pressurized while running or the hoses should be soft the same as with cold engine? If there should be pressure, what causes it? I assume that the cooland doesn't expand with temperature, right? Anyway, the pressure is not so high as with my old faulty head gasket (my hoses were hard like stone, now you can push it).
3) If I don't bleed all the air form the system, will the bubbles go out itself after some time?
Thank you,
Petr
Old Apr 16, 2004 | 07:22 AM
moto27cm's Avatar
Default Re: Head gasket changed - results (petrv)
1.I always fill the rad up to the top, then run the car with the cap off for a few minutes. Fill as necessary.
2.With the cap on, the system is presurized, but not to the point that the hoses become solid.
3.I would bleed the system. its fairly easy to do. Ther should be a bleeder screw by the thermostat or on the head.
88 EF Hatch
Jul 11, 2009 09:54 AM
efjones9
May 1, 2009 06:48 PM
1991b20bteg
Nov 9, 2008 02:43 PM
bigizsosexy
May 5, 2006 12:14 PM
petrv
Apr 16, 2004 06:17 AM
