Rebuilding tranny, how hard is it to replace syncros?
Old Apr 14, 2004 | 07:13 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Rebuilding tranny, how hard is it to replace syncros?
The tranny in the ITR is getting pretty scratchy. 1st to 2nd gear at redline with a fast shift is met with a crunch . I've been suspecting my input shaft bearing of being shot and plan on installing a new one when I pull the engine for a rebuild, but I'm also planning on finding my syncros to be crapped out. Maybe the input shaft bearing is causing these problems as well, but I'm never that lucky
So if I have the time, patience, and a daily driver how hard is it to change syncros, if nessecary. Purchasing the needed tools shouldn't be a problem and I have a Helms manual. Anything to look out for? Would it be better to just pull the tranny and open the case myself and let a shop handle the actual syncro replacement? Any info would be appreciated.
Old Apr 14, 2004 | 07:30 AM
RedlinedVTEC's Avatar
Default Re: Rebuilding tranny, how hard is it to replace syncros? (ActiveAero)
Open it up and do it yourself. You say time isn't an issue so you can afford to take you time and do it right by yourself. Just go through the special tools page in your helm's tranny section to see what you'll need to go out and by. Just take your time and keep track of everything, maybe take pictures during disassembly to help you out.
Old Apr 14, 2004 | 07:44 AM
Dan GSR's Avatar
Default Re: Rebuilding tranny, how hard is it to replace syncros? (RedlinedVTEC)
read the tranny section of the helms manual at least 3 times
before diving into this
also take a look at IN VTEC 's post
https://honda-tech.com/zerothread?id=795700
get yourself a good three prong gear puller
some 2x4's
good snap ring pliers
torque wrenches
other misc stuff
ricky tan
Oct 5, 2012 07:57 AM
prelude182
Aug 18, 2009 04:05 PM
reeder321
Apr 21, 2004 02:44 PM
Jockobo
May 24, 2002 02:52 AM
SoloSol
Jan 28, 2002 07:16 AM
