D16Z6 need help
Old Apr 13, 2004 | 06:31 PM
hon95's Avatar
From: 28952 Longmeadow Loop, Wesley Chapel, FL, USA
Default D16Z6 need help
Just rebuilded my engine and when I went to started for the first time it just did a whooping sound, like if the battery did not have enought current to turn the crankshaft. Can you think of something that I did wrong.
Old Apr 13, 2004 | 06:34 PM
mmuller's Avatar
Mad Scientist
Default Re: D16Z6 need help (hon95)
is your battery charged?does the engine turn by hand?
Old Apr 13, 2004 | 06:49 PM
hon95's Avatar
Default Re: D16Z6 need help (mmuller)
Yes, and I even changed out batteries. The engine turns by hand but its kind of hard to turn.
Old Apr 13, 2004 | 09:29 PM
Redline130's Avatar
Unplug the distributor and crank the motor over to get some oil pressure built up in the motor. Might just be that the cylinders are too dry.
Old Apr 15, 2004 | 01:53 PM
tgreaves's Avatar
Did you plasitgauge your bearing to make sure they were within spec..
Old Apr 16, 2004 | 06:05 AM
nota-ex's Avatar
Default Re: D16Z6 need help (tgreaves)
uhh, is the timing belt right? my friend did some **** to his car and didn't do the belt right. said he went to start it and it made a funny noise and bent his valves.
Old Apr 16, 2004 | 08:54 AM
Honda Crx's Avatar
Default Re: D16Z6 need help (NOTA-EX)
sounds like a dizzy to me but im no mechanic
Old Apr 16, 2004 | 09:30 AM
tgreaves's Avatar
Default Re: D16Z6 need help (Honda Crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Crx &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a dizzy to me but im no mechanic</TD></TR></TABLE>
I dont think the dizzy would make it hard to turn over..
Just to check it remove the dizzy and try to crank it over by hand.. If its still hard then its something else..
I asked you in a previous post, If you rebuild the motor did you plastigauge to check the clearances on the bearings..
N7J3H2C
10
Jul 27, 2007 06:45 PM
dr_latino999
Aug 7, 2005 12:32 PM
mycarisdead
Jan 4, 2005 06:30 PM
beauduvall
Feb 10, 2004 09:05 AM
beauduvall
Feb 10, 2004 06:08 AM
