Usual cause of steering slack?
Old Apr 16, 2004 | 07:28 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Usual cause of steering slack?
My 1991 Si beater car has gained a VERY noticeable amount of steering slack, which makes it very disconcerting to drive. Is it possible for the teeth on the rack to be worn out or is the problem usually traced to somwhere in the suspension? Shot bushings maybe? I want to have some idea, if possible, before I crawl under the car. Thanks in advance.
Old Apr 16, 2004 | 11:15 PM
zensoku207's Avatar
probably a dumb question, but do you have PS in the car? it could be from too much fluid in the reservoir.
Old Apr 17, 2004 | 10:09 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: (zensoku207)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zensoku207 &raquo;</TD></TR><TR><TD CLASS="quote">probably a dumb question, but do you have PS in the car? it could be from too much fluid in the reservoir.
No.
Old Apr 17, 2004 | 10:46 AM
zensoku207's Avatar
Maybe that rack is loose?
Are there any noises when you try to turn?
Old Apr 17, 2004 | 05:42 PM
doublejz's Avatar
inner tie rod ends? rack starting to go bad?
davidzil
Honda CR-V & Element
Apr 15, 2013 10:16 AM
b20beast83
Suspension & Brakes
Oct 21, 2008 01:31 PM
02_Si_FTW
10
Mar 19, 2008 05:49 AM
BlueLude 94
Jan 24, 2006 11:18 AM
