Results of Leakdown test : what to do now??
Old Apr 13, 2004 | 08:20 AM
eswaroop's Avatar
Default Results of Leakdown test : what to do now??
Hi,
I had a leak down test done today and the results are 8 % on two of the cylinders and 12% on the other two. They say that the rings have seized up due to carbon and that is what is causing the leak.
What do I do now?
Thanks
Es
Old Apr 13, 2004 | 08:29 AM
mmuller's Avatar
Mad Scientist
Default Re: Results of Leakdown test : what to do now?? (eswaroop)
thats pretty high, start by buying some seafoam and cleaning you combustion chambers.
take spark plugs out, put like 2 caps of it on each cyl. and start the car(lots of smoke) and repeat
Old Apr 13, 2004 | 09:26 AM
02Si_DinanEmp's Avatar
What is your complaint with the car (for example, is it slow on acceleration), and was the leakdown/compression(they did both right?) done when the car was cold or when it was at operating temperature?
Old Apr 13, 2004 | 02:28 PM
cheap_autorepair's Avatar
That leak down result is okay. Y did u do a leak down test? what is the problem?
Old Apr 13, 2004 | 06:27 PM
mmuller's Avatar
Mad Scientist
Default Re: Results of Leakdown test : what to do now?? (cheap_autorepair)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheap_autorepair &raquo;</TD></TR><TR><TD CLASS="quote">That leak down result is okay. Y did u do a leak down test? what is the problem?</TD></TR></TABLE>
so you think 12% leakdown is ok.....mmmmm yea
even 8% is a lot by honda standarts....my b18b with 120k miles had 5% and i just swapped a gsr motor with 93k and it had between 2% and 3%...
killudie123
Nov 6, 2011 12:13 PM
1badteg
Jul 16, 2007 02:00 PM
DRKSol
Jan 19, 2006 01:18 AM
turbob18a
Oct 1, 2002 09:24 AM
