What size fitting to fit in spark plug hole???
Old Jan 21, 2003 | 06:13 AM
Stewie's Avatar
Default What size fitting to fit in spark plug hole???
What size fitting is needed for the spark plug hole on a 99 Integra to do a leakdown test/ compression test. I only have seen two, 14mm and 18mm. I use a 16mm socket to remove the spark plug, so I'm confused!
Can someone help me out?
thanks
Old Jan 21, 2003 | 06:26 AM
RaceTilIDie's Avatar
Default Re: What size fitting to fit in spark plug hole??? (Mac8008)
14 mm diameter threads. Your plugs have a 19 mm reach and 16mm hex on the outside to remove them.
Old Jan 21, 2003 | 06:42 AM
Stewie's Avatar
Default Re: What size fitting to fit in spark plug hole??? (RaceTilIDie)
thanks for the fast reply
thai-lorn
Jan 15, 2007 02:02 PM
bjfisher
May 9, 2006 09:49 PM
crx_88_si
May 1, 2006 08:13 AM
PearlWhiteAccord
Jan 15, 2004 10:43 AM
CPR
Sep 11, 2002 11:04 AM
