How do i tell if rotor is warn?
Old Jan 22, 2003 | 06:23 PM
totaled's Avatar
Default How do i tell if rotor is warn?
How can i tell if the rotor on my 97 civic ex is worn and needs to be replaced, i needed a new cap and got a rotor 2 and the damn screw is impossible to get out of it , its in such a strange place, but im wondering how do i make sure i need to replace it?
Old Jan 22, 2003 | 06:51 PM
Shawn C's Avatar
In The Garage
Default Re: How do i tell if rotor is warn? (totaled)
current mileage would help, but id replace it. the screw is easy to get to, youve just gotta unplug the distributor and slowly crank the engine a little at a time, until you can get to it.
Old Jan 22, 2003 | 07:00 PM
totaled's Avatar
Default Re: How do i tell if rotor is warn? (22lbGS-R)
yea i just started the car twice till it ended up at a good spot, all done, but thanks.
Old Jan 22, 2003 | 07:40 PM
Shawn C's Avatar
In The Garage
sure mang. by the way, i always replace the plugs, wires, cap, and rotor every year. not totally nessesary, but i guess im just weird like that
Old Jan 22, 2003 | 09:51 PM
totaled's Avatar
did plugs rotor and cap, waiting for wires to come (NGK for $52)
Old Jan 22, 2003 | 10:05 PM
Shawn C's Avatar
In The Garage
good choice
Old Jan 23, 2003 | 05:15 AM
fathergoose's Avatar
maybe the screw is not facing you. Try to crank the engine little by little until the screw is facing you. Then you will be able to remove it. You can also use a 17mm on on the powerstreering pulley conterclockwise until the screw is facing you.
A worn rotor is all oxydized on his tip, if you see too much oxydation, replace the rotor.
Old Jan 23, 2003 | 11:54 AM
totaled's Avatar
Default Re: How do i tell if rotor is warn? (fathergoose)
thanks everyone.
What i did was attached the cap by one screw, started the car, waited till the SRS light came off, turned it off. opened it up, and the screw was in the perfect spot. My goodluck ^^ new rotor and cap on now, wires should come soon from a group buy for $52
xstalkrx
May 21, 2007 04:34 PM
2ndName
Jan 30, 2006 11:32 PM
ricemikecd5
Jun 14, 2004 03:23 PM
machinehead
Oct 21, 2003 04:14 PM
vuthe32
Sep 7, 2003 02:22 PM
