Brake Fluid/Clutch Fluid
Old Jan 22, 2003 | 11:26 AM
integra6650's Avatar
Default Brake Fluid/Clutch Fluid
Any recomandations on which is the best and best performing of these two fluids
Old Jan 22, 2003 | 11:40 AM
BROOD's Avatar
Default Re: Brake Fluid/Clutch Fluid (integra6650)
I use Valvoline Synthetic Brake fluid in both...works great, is affordable, and easily found. I flush the brake system pretty often though.
[Modified by SLPR, 12:41 PM 1/22/2003]
Old Jan 22, 2003 | 11:41 AM
Volcom's Avatar
Valvoline SynPower is the best for a tight budget. That's what I'm rocking in the clutch system right now. I plan on bleeding the brakes on of these days with the same stuff.
Old Jan 22, 2003 | 12:33 PM
ejprimo's Avatar
Default Re: Brake Fluid/Clutch Fluid (Volcom)
i use castrol LMA. it can be found at pep boys.
Old Jan 22, 2003 | 02:12 PM
Lord Helmet's Avatar
Default Re: Brake Fluid/Clutch Fluid (SLPR)
that's why I buy it
Old Jan 22, 2003 | 03:12 PM
TypeSH's Avatar
Default Re: Brake Fluid/Clutch Fluid (sleeperciv)
that's why I buy it
how much is it? what do u guys think of ATE Superblue?
Old Feb 10, 2003 | 03:01 PM
EGO's Avatar
EGO
Default Re: Brake Fluid/Clutch Fluid (TypeSH)
I've heard a lot of good things about Superblue, but how accurate and realistic is another story. This is usually the case in applications like most of the people on here fall under. I believe for one to truly feel the affects of a given better performing brake fluid over a typical off the shelf brand, they would have to actually race the car and pit the different fluids against eachother to find the better performing one. ATE Super Blue has a wet dry boiling point of 280C degrees celcius (536F) and wet boiling point of 200C (392F). It's supposed to absorb moisture very slowly, so you can leave it in for a long time.
I just ordered a bunch of brake parts (Axxiss Ultimate pads, ATE Super Blue, Speed Bleeders and steel braided lines) and will be installing them late in the week. I'll let you know what kind of performance gain I feel from the upgrade.
Ant
Old Feb 10, 2003 | 05:08 PM
Default Re: Brake Fluid/Clutch Fluid (anthony m.)
thanks i went out and bought the valvoline but lemme know how much time you save on those speed bleeders
Old Feb 11, 2003 | 04:50 AM
BROOD's Avatar
Speedbleaders are a good time saver, just make sure to keep the little rubber cap on them while driving...to keep dirt/corrosion out of them.
kpjo4
Oct 19, 2010 09:48 AM
vdg721
Oct 25, 2007 10:38 AM
1990AccordEX
Oct 29, 2006 01:55 AM
CivicSiRacer
24
May 15, 2003 12:03 PM
