zc motor... direct fit?
Old Jan 23, 2003 | 02:40 PM
jester's Avatar
Default zc motor... will it bolt up in my stock rex?
I have an 88 dx crx and I was wondering if the dohc zc motor is a direct bolt up match for my car?
[Modified by jester, 7:13 PM 1/23/2003]
Old Jan 23, 2003 | 03:00 PM
eg6ajk's Avatar
Default Re: zc motor... direct fit? (jester)
yes it will bolt up to your tranny as well to the mounts you have. longest its 88-91 DOHC/SOHC ZC from Civic/CRX (aka black cover)
it will require you to do some wiring adn few little small changes. very easy swap and makes the car feel much better
http://www.hybridgarage.com/tech/4gtech/index.html
Old Jan 23, 2003 | 03:10 PM
jester's Avatar
Default Re: zc motor... direct fit? (eg6ajk)
As far as the ZC engine goes, is it a strong motor? Basically im looking for dependability because my car is an everyday driver.
Old Jan 23, 2003 | 03:43 PM
Flexmyrex's Avatar
first thing you have to do is convert to mpfi, then everything else should bolt right in. no aftermarket mounts needed. zc is a pretty reliable motor, at least mine was.
if i were you i would rather save a little more and go w a b series, but its all you.
Old Jan 23, 2003 | 04:04 PM
qcoffey's Avatar
Default Re: zc motor... direct fit? (flexmyREX)
Direct bolt in not hard at all. You can even use your dx tranny(wouldn't reccommend because of gearing). Get an 90-91 Si tranny or, ZC tranny(uses ontermediate shaft). Engines are cheap and reliable.
Old Jan 23, 2003 | 04:13 PM
tz-devil77's Avatar
Default Re: zc motor... direct fit? (qcoffey)
the hardest thing with the zc is converting the wiring harness for the dx. The rest is easy. If you can find a jdm ecu that would be better. For the money unless you build the b16, the zc is faster stock. but that is my opinion. I had a 89 crx hf with a zc and si trans, jdm ecu, it ran 15.1 in the quarter and i drove it 100 miles to work and home.
Old Jan 23, 2003 | 04:18 PM
jester's Avatar
Default Re: zc motor... direct fit? (tz-devil77)
There is a swap im looking at that has the motor and trans. but I would plan on buying the zc ecu... Also would it be best for me to get the 90-93 teg axles.... and to tz-devil77 big ups for NC
[Modified by jester, 8:33 PM 1/23/2003]
Old Jan 23, 2003 | 04:51 PM
jester's Avatar
Default Re: zc motor... will it bolt up in my stock rex? (jester)
How expensive do you guys think a dx-zc wiring harness will cost? heh homemade from a h-t member or a company ... either or
Old Jan 23, 2003 | 05:41 PM
Hondasaurs's Avatar
Its easy to do your self. Make sure you use the DX harness though.
BuddhasGift2You
Nov 10, 2005 11:57 PM
88crxdxfastwhip
Aug 10, 2005 11:30 AM
EK_vzla
24
Jan 9, 2004 10:50 AM
zc crx
11
May 26, 2002 10:05 PM
johnny hatchback
Mar 25, 2002 04:32 AM
