Crack head gasket... Help
Old May 5, 2006 | 07:51 AM
bigizsosexy's Avatar
Default Crack head gasket... Help
1. I have pressure(air) in the coolant lines lower and upper, ive been told its my head gasket, but there is no coolant in the oil, just changed the thermostat and had it tested and they said it was the Head gasket does this sound right to you guys?....input please
Old May 5, 2006 | 08:19 AM
devnull's Avatar
on the head there is a little escape valve. 10mm, loosen it cold then start the car and let it run till it warms up when it starts spitting fluid in a clean stream (not air) then you are good, close it back and clean up. Keep the reserve full while doing this.
Or you can do the lazy man method of un-capping the the radiator and doing the same thing. Just be sure to keep the radiator full while you are doing this.
Old May 5, 2006 | 12:14 PM
rmcdaniels's Avatar
Default Re: Crack head gasket... Help (bigizsosexy)
Sometimes the head gasket will just leak combustion gases into the water jacket when a head gasket goes bad, but I mostly see that in boosted motors. Look to see if your overflow tank is coated with black crud on the inside and see if gray oily sludge is building up on the bottom of your radiator cap.
teggy96
Mar 9, 2011 04:52 AM
efjones9
May 1, 2009 06:48 PM
1991b20bteg
Nov 9, 2008 02:43 PM
windgatgp
Aug 20, 2007 12:33 PM
john457
Mar 17, 2007 08:11 PM
