No VTEC - B16a Help... I've tried everything I know !!!!!
Old May 3, 2006 | 07:32 PM
Firestarter's Avatar
Default No VTEC - B16a Help... I've tried everything I know !!!!!
I have a civic that had a motor swap, it has no vtec, It was tested when the motor was warm/ hot.
1>the VTEC solenoid has been tested (it was jumpered & there was a jump in oil pressure)
2> the temp gauge & the speedo work
3> NO CEL.
4> oil level is good
Old May 3, 2006 | 07:36 PM
Chiovnidca's Avatar
Default Re: No VTEC - B16a Help... I've tried everything I know !!!!! (Firestarter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Firestarter &raquo;</TD></TR><TR><TD CLASS="quote">
1&gt;the VTEC solenoid has been tested (it was jumpered & there was a jump in oil pressure)
How much oil pressure? Your using a vtec ecu?
Old May 3, 2006 | 07:39 PM
hondakevin21's Avatar
I'd say check the wire from the ecu to the solenoid using a wiring diagram, if that isn't it make sure you have the right ecu.
Old May 3, 2006 | 07:49 PM
Default Re: No VTEC - B16a Help... I've tried everything I know !!!!! (hondakevin21)
I'm using a vtec ecu. I donot remember the oil pressure reading. But when it engaged there was an audible difference.
"I'd say check the wire from the ecu to the solenoid using a wiring diagram"--- I attempted that got lost along the way (I found the pin on the ecu... b16 if I'm not mistaken ) although I'm not too sure how to test it with the test light . since it activates around 5k rpm when the car is in motion
Old May 3, 2006 | 10:39 PM
powerfulperformance's Avatar
try checking to make sure that all the pins in the rocker arms are there. My friend wasn't hitting vtec and i found out that one rocker arm didn't have a pin..
Old May 4, 2006 | 02:50 PM
Default Re: No VTEC - B16a Help... I've tried everything I know !!!!! (powerfulperformance)
I wouldn't check the ecu with a test light because it sends back a small voltage and can hurt you ecu, don't do it use a digital multimeter.
Old May 4, 2006 | 05:35 PM
I 'm not too sure what to do with the multi meter, I'm just aware of the beep noise mode.- "It beeps when a power manages to flow from + to -" I 'm also not too sure how to test the circuit .
tankizk
Jul 24, 2007 10:36 PM
streetracerjoey210
11
Sep 23, 2006 03:53 PM
oldschoolfreak
Feb 7, 2005 06:12 PM
JinDIESEL
Sep 28, 2004 05:46 AM
HatchBox
40
Nov 23, 2003 05:22 PM
