440cc injectors in a R motor??
Old May 8, 2006 | 03:55 PM
Eg_TypeR's Avatar
Default 440cc injectors in a R motor??
I put 440cc injectors in my type R motor and it ran like crap!!!
a lot of black smoke was puffing out, and idled like ***.... way too much fuel!!
wut should i do, tune the car for the injectors(if possible), or should i get a set of lower rating injectors??
Thanx
Old May 8, 2006 | 04:16 PM
rainforest's Avatar
Default Re: 440cc injectors in a R motor?? (Eg_TypeR)
get smaller injectors and tune it. unless you have a crazy all motor build or mild turbo you don't need 440cc injectors. obey you own advise and keep it simple.
Old May 8, 2006 | 05:28 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg_TypeR &raquo;</TD></TR><TR><TD CLASS="quote">I put 440cc injectors in my type R motor and it ran like crap!!!
Thanx
if its tuned properly with good software, then it should idle like stock. i run 550's and idle like stock.
Old May 8, 2006 | 05:46 PM
non-VTEC's Avatar
you cant just put in larger injectors and expect it to run right........
Old May 8, 2006 | 06:30 PM
b20vtech's Avatar
GET IT TUNED!!!!! u could run 1000cc injectors if it's tuned......
Old May 8, 2006 | 07:15 PM
Eg_TypeR's Avatar
Thanx... gonna tune it in a couple of weeks
Old May 9, 2006 | 01:43 AM
rainforest's Avatar
Old May 9, 2006 | 07:19 AM
Buzzbomb's Avatar
I think a better question here is what is done to your engine that warrants 440 injectors?
Old May 10, 2006 | 05:46 PM
Eg_TypeR's Avatar
Default Re: 440cc injectors in a R motor?? (Buzzbomb)
First of all... Its not like i went out looking specifcally for 440cc injectors.... the just came to me for a really good price...
its a B18c5 block with oversized pct pistons and a JDM R head and a crap load of little bolt ons...
Old May 10, 2006 | 06:20 PM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg_TypeR &raquo;</TD></TR><TR><TD CLASS="quote">First of all... Its not like i went out looking specifcally for 440cc injectors.... the just came to me for a really good price...
its a B18c5 block with oversized pct pistons and a JDM R head and a crap load of little bolt ons...</TD></TR></TABLE>
That's nice.
Look, your ECU is set to control the stock injectors. If you put larger injectors in, the ECU doesn't know this and is going to open and close them at the same rate as if the stock injectors were still there. Since the injectors are larger than the stock ones (almost twice as big), way too much fuel (twice as much) is going to go in resulting in a crappy running car, which you experienced first hand.
Your best bet is to resell them and make some money off of them. Your setup does not require larger injectors. While your at it, sell the AEM fuel rail and make some money off of that too since that is not adding any performance either. Oh, and the MSD ignition too.
Old May 10, 2006 | 06:58 PM
raphael's Avatar
buzz so after he sold the injectors and rail who would u go forth into making real power out of this motor with that money saved?
Old May 11, 2006 | 05:17 AM
Buzzbomb's Avatar
Default Re: 440cc injectors in a R motor?? (raphael)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raphael &raquo;</TD></TR><TR><TD CLASS="quote">buzz so after he sold the injectors and rail who would u go forth into making real power out of this motor with that money saved?</TD></TR></TABLE>
I'm not sure what your asking exactly because of your fragmented sentence, but I think you're asking what I would do with the money to make the engine more powerful?
I honestly would leave it alone and spend the money on something else or save it. If, according to his screen name, he has a B18C5 in an EG then it's a very fun car as is. He could spend the money on some engine management but probably wouldn't see enough gains to warrant the expense.
It's better to just enjoy the car and read and research what you want to do and what you need to do it instead of buying stuff, putting in on, and wondering why it doesn't work. If you are patient then not only do you have the money to do what you want, you run into alot less headaches doing it.
Old May 11, 2006 | 07:38 AM
BMaDOHC's Avatar
tune and leave it alone, not everyone wants 10 second slips. a nice powerful daily driver that smokes shitstangs and camaros is good enough for me.
Old May 11, 2006 | 10:26 AM
ChicagoMike's Avatar
440's in that motor is fine. Its all about the tune.
Mxl973
May 2, 2017 01:08 PM
01typerboi
Dec 23, 2010 12:42 PM
tarheelsoldier
Mar 28, 2007 11:44 AM
blocburner1
Jan 14, 2006 05:48 AM
J-Spec EG
Apr 27, 2004 05:40 AM
