VAFC or Chipped ECU?
Old May 5, 2006 | 05:22 AM
roadracer321's Avatar
Default VAFC or Chipped ECU?
I am trying to figure out which to go with? Both do pretty much the same thing for my B18C. I am not to familar with programming and adjusting the VTEC and fuel curves. I am definitely willing to learn them though, but where would I get most of my power gain? VAFC or the chip? I will be runing the OBD1 P72. Also, how will this effect emissions? I live in the second worst state for emissions, and that is MA. Let me know what you all think...
Old May 5, 2006 | 05:34 AM
Umm1.8t's Avatar
Default Re: VAFC or Chipped ECU? (roadracer321)
Yeah what he said!
Old May 5, 2006 | 07:23 AM
devnull's Avatar
Since you are worried about emissions (I say GOOD for you) I would recommended chipping it. Reason being that chipping you can change chips relatively easily. And some states will not let you pass visual with a VAFC as it is not a certified electronic device for modifing engines. Also if you ever dyno tune you can be far more specific with your tuning and even can tuning POT for crusing so you can still get good MPG.
Old May 5, 2006 | 09:17 AM
<---Dumb
Define Tuning POT
Old May 5, 2006 | 09:23 AM
devnull's Avatar
POT = Part Open Throttle (crusing)
Old May 12, 2006 | 11:09 AM
LatinEM2's Avatar
what would you guys recommend for a 00 civic si with just bolt ons?? VAFC or a tuned ECU??
Old May 12, 2006 | 07:08 PM
category5 SI's Avatar
Default Re: (LatinEM1)
Don't get one of those Ebay chips for your ecu,all they do is make your car run rich and give you crappy gas mileage.A VAFC street tuned with a wideband works very well,, I had one on my 99SI.If you get someone that really knows what there doing you can get good results.Put in your glovebox if your worried about it being seen.
Old May 15, 2006 | 08:57 PM
solofthesouth's Avatar
what could i see out of a stock b16 with a phreable(sp?) chipped ecu and a VAFC for fine tuning? would it correct my richness and timing?
Old May 16, 2006 | 11:57 AM
b18sihatch's Avatar
i also would agree wideband tuner and a vafc could do the trick for light bolt on modifications.
Old May 17, 2006 | 09:07 AM
gents97civ's Avatar
vafc for light modifications. If you do more than intake and exhaust I would say go with a chipped ecu. The reason I say this is that a vafc controller is a piggy back system and tricks the ecu. This can be harmful because you can only adjust the fuel and you will have the wrong timing at the wrong rpm.
Old May 17, 2006 | 10:18 AM
Relic1's Avatar
actually a VAFC changes the map readings to get less fuel. the problem is this also changes timing. (depending on what is in the maps)
Not a big deal until you happen to hit a large change in the map, then things can get bad quickly.
IMO, OBD1 ECU + tuned maps for anything over bolt-ons. Anything less than that you're better off with the stock maps anyway.
Old May 21, 2006 | 04:49 AM
thahuhstunna's Avatar
use a VAFC, but only if you're going to tune it on a dyno...otherwise use the chipped ecu
Old May 21, 2006 | 08:59 AM
98vtec's Avatar
moderator emeritus
Default Re: VAFC or Chipped ECU? (thahuhstunna)
P72 with crome. All you need to do is socket the ecu and run a 256k chip with a basemap. Then go to a tuner and get tuned.
Crome is free and a hell of alot better than any bs vafc.
VTECU
Nov 14, 2006 11:07 PM
Richard.
Nov 23, 2003 12:36 PM
Champ R
Nov 21, 2003 03:26 PM
satan_srv
Sep 13, 2003 11:32 AM
yaya
Mar 30, 2003 02:56 PM
