valve adj. screw stuck need help
Old May 8, 2006 | 05:42 PM
import810's Avatar
Default valve adj. screw stuck need help
Since my car wouldn't start I was recommended to do a valve lash test. I go out there and the number 3 cylinder exhaust side (right one) valve adjustment screw wont unscrew. The locknut moves fine but that damn screw won't move. What should I do?
Old May 8, 2006 | 05:45 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: valve adj. screw stuck need help (import810)
It isn't at a limit is it? Do the threads seem to be damaged? You may need to replace the rocker.
Old May 8, 2006 | 06:53 PM
postman's Avatar
was the lash off before you tried to adjust the valve.
Old May 8, 2006 | 09:19 PM
import810's Avatar
Default Re: valve adj. screw stuck need help (postman)
yes
$$broke_db8
Jul 5, 2006 05:09 AM
HulkSmash
Apr 12, 2004 10:40 AM
