zex safe kit?
Old May 9, 2006 | 11:46 AM
JJBRADLEY's Avatar
Default zex safe kit?
i am thinking about hooking up zex to my 99 si after i replace the internals and pistons. i just wanted to get some feeback on the kit before i figure out what im gonna do.
Old May 9, 2006 | 01:15 PM
HandoEX's Avatar
Default Re: zex safe kit? (JJBRADLEY)
Zex makes a good kit. They are relatively inexpensive and easy to hook up and use. The Zex kit I have is set up to use wide open throttle activation so that the nitrous will only spray at WOT when the system has been engaged (instead of a push button activation system). Get colder plugs and use 92+ octane fuel and you should be ok up to a 75 shot. A window switch is a necessity so that you can set your nitrous system up to shut off at an rpm level before you hit fuel cut. Fuel cut + nitrous will lead to a blown motor. A bottle heater is a great investment to keep your bottle at the optimal pressure level. Good luck
eg six
May 29, 2006 05:45 PM
MajinB
Mar 20, 2006 05:02 PM
mk2
Jan 5, 2005 07:51 PM
PreludePhill
Jan 28, 2004 10:19 PM
v-tec crx
13
Dec 26, 2001 06:19 AM
