Fitting an itr lsd in a GSR Trany
Old May 6, 2006 | 07:13 PM
CroteTurbo's Avatar
Default Fitting an itr lsd in a GSR Trany
I try to fit my itr lsd in my ls trany and it don't work because of the final drive.
Will it direct fit in a gsr trany with the proper shim?
Old May 7, 2006 | 04:40 AM
CroteTurbo's Avatar
Default Re: Fitting an itr lsd in a GSR Trany (CroteTurbo)
Anyone?
Old May 7, 2006 | 05:07 AM
Dogginator's Avatar
Daisy... Daisy...
Yes. It is a perfect fit. You will need the gamut of shims for the differential. Are you planning to use the tapered roller bearings or the ball bearings for the differential?
Old May 7, 2006 | 05:55 AM
CroteTurbo's Avatar
Default Re: Fitting an itr lsd in a GSR Trany (Dogginator)
I'll put the ball bearing not the taper ones
So the final drive of an usdm gsr will bolt on the itr lsd jdm or usdm right?
Old May 7, 2006 | 06:13 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CroteTurbo &raquo;</TD></TR><TR><TD CLASS="quote">I'll put the ball bearing not the taper ones
So the final drive of an usdm gsr will bolt on the itr lsd jdm or usdm right?</TD></TR></TABLE>
Yes it will.
DJ Gurgla GSR
Jul 3, 2006 12:23 PM
tekstyle
Jun 15, 2004 05:59 PM
kool168
Feb 19, 2004 06:13 AM
JDM CRX
Feb 3, 2003 07:40 PM
