Did head swap...now timing is off...
Old May 8, 2006 | 09:10 AM
Dublin's Avatar
Default Did head swap...now timing is off...
Did a swap over the weekend...I had never done a head swap before but a friend that was helping me had helped another guy do his...this is the weird part...when we put the head back on, he said we were supposed to have cylinder 2 & 3 TDC and have the notches on the cam gear straight up and down...everwhere else i heard, cylinder 1 & 4 are supposed to be TDC and the cam gear notches parallel to the top of the block (with the UP spoke up)...now the timing is way off... has anyone done this before?...should i redo the timing belt with 1 & 4 TDC and have the notches even with the block?
Old May 8, 2006 | 09:11 AM
Dublin's Avatar
Default Re: Did head swap...now timing is off... (Dublin)
BTW...D16Y8 on a D16Y7 block...mini me swap...
Old May 8, 2006 | 02:17 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dublin &raquo;</TD></TR><TR><TD CLASS="quote">...should i redo the timing belt with 1 & 4 TDC and have the notches even with the block?</TD></TR></TABLE>
It's easyier to tell if it's set right that way. You dont really need to redo it, just spin it over and check to make sure it's right.
ekwolf1986
26
Aug 30, 2009 07:46 PM
that1kid
Mar 16, 2007 07:40 AM
Dublin
May 12, 2006 08:47 PM
O RLY
Mar 26, 2005 08:36 PM
