Air in coolant line
Old May 1, 2006 | 09:30 AM
bigizsosexy's Avatar
Default Air in coolant line
I having air come into my coolant lines, changed thermostat and rad cap ....anyone no the problem? LS motor
Old May 1, 2006 | 09:49 AM
bOOsted_D16's Avatar
Default Re: Air in coolant line (bigizsosexy)
were your thermostat is there is a little bolt that u can un-srew and it will let the air out..jus like when u blead a brake system...so try that
Old May 1, 2006 | 09:56 AM
Allready did thanks though still didn't help keep the answers comming pleez
Old May 1, 2006 | 10:10 AM
are you loosing the water 2? and the air is building up?
Old May 1, 2006 | 10:11 AM
no , just air is in the lines everytime, regaurdless whether i am boosting or at idle and when i stwist the rad cap is just pshhhhhhh with air
Old May 1, 2006 | 10:13 AM
dam thats not good man....i dont know what it could be...try searching it
Old May 1, 2006 | 10:23 AM
Default Re: Air in coolant line (tjay92accord)
yeh i know thanks though where should i search ive tried everywhere
Old May 1, 2006 | 11:05 AM
91DA9's Avatar
That is very strange, have you checked the exhaust to see if it is burning coolant? It is a closed system (normally) so, the coolant has to be going somewhere to let the air in. Check your oil for coolant as well. How long has it been doing this? I would suggest checking the heater core, or around the HVAC box for coolant if it has just started happening recently.
I am assuming you top it off when it is cold and it loses the coolant after it has run for a while? That is a pretty serious problem, as cavitation can really screw up soft aluminum engines.
Old May 1, 2006 | 11:16 AM
EE_Chris's Avatar
With engine cold, heater control to full hot (fan is NOT on though) and the radiator cap off, start the car.
Allow it to idle till the cooling fan kicks on/off. Install radiator cap.
On 6th gen Civic's (what I have), there isn't a bleeder bolt located on the thermostat like some earlier models, so I have no input on it.
Old May 1, 2006 | 12:54 PM
Default Re: Air in coolant line (EE_Chris)
check around the passenger floor board and see if its wet if it is then your heater core is leakin....like some1 else said it is usually a closed system but somewhere air is gettin in....check your oil as well as you exhaust and see if water is in them
Old May 14, 2006 | 07:34 PM
Thank you guys, seemed to be a bad head gasket and the head was warped 2cm off, had it sent to the machine shop everything is running pretty smooth thank again
wicked_b16eg
Dec 30, 2007 09:57 AM
97grnrs
Jun 12, 2006 05:21 PM
93FastLs
Dec 20, 2004 02:03 PM
HUBB
Jun 4, 2004 11:00 AM
1.8T_EG
Oct 28, 2002 04:17 PM
