Ebdyn Block Posts, a horror story
Old May 8, 2006 | 03:36 PM
swapdohc's Avatar
Default Ebdyn Block Posts with sleeve failure
So heres my story....
I built a b16a3 block using Endyn 9:1 pistons, Eagle rods and Endyn block posts, the engine was blueprinted and block posts installed at a supurb machine shop. The engine was broken in properly under various loads at varios RPMs on my Dyno Dynamics Dyno. We ran 10 PSI and made 280 whp with the AFRs around 11:1 at WOT with EGT's never exeeding 1550 degrees (About 2 in from head)
This is the result after 1000 miles:
It is clearer seeing it in person, but the block posts don't spread the load adequitly, most of the load applied to the sleeve is absorbed by only the tiny area provided by the block post (As compared to a block guard which spreads it out).
I would apreciate your input on why you think this happened, I don't mind being wrong so if you see something I don't PLEASE point it out.
BTW This engine was assembled by me with great attention to detail and every torque spec was adhered to. The block posts were installed by the machine shop with direction coming directly from Larry at Endyn.
I WOULD LIKE TO MAKE IT CLEAR THAT THIS IS NOT AN ATTACK ON ENDYN!!!
This is an attempt to understand what happened, I love Endyns pistons and will continue to use them in the future.
Thank you
Modified by swapdohc at 4:51 PM 5/8/2006
Old May 8, 2006 | 08:26 PM
FMIDRC Racer's Avatar
man i still can't beleive that ****. build a dart block already!!!!
Old May 8, 2006 | 10:43 PM
Combustion Contraption's Avatar
Love endyn pistons? Look at your piston tops.
Flame propogation 101.
Old May 9, 2006 | 12:54 AM
p-crack's Avatar
Default Re: Ebdyn Block Posts with sleeve failure (swapdohc)
the tune or fuel delivery failure most likely
Old May 9, 2006 | 03:41 AM
swapdohc's Avatar
Default Re: (Combustion Contraption)
I noticed that as well, but I believe that the poor combustion in #3 was caused by the process of the sleeve cracking.
The flame propagation through that combustion chamber was effected by the cracked sleeve before it failed. I did a compression test the day before this happened and that cyinder was low by about 15 PSI, this surely got worse before sleeve failure which would help to cause the incomplete/uneven burning of fuel through lower cylinder pressures. The cylinders, #3 in particular, were burning coolant before failure as well (As reported by the driver behind me when the sleeve failed), this would also contribute to a incomplete burn. The rest of the cylinders have a much better burn pattern and also were not as heavily steam cleaned before and during the failure.
This happened at 7000ish rpms and shut down the motor immedietly. There was no fuel delivery failure nor any signs of a lean condition or detonation, including on the plugs so I don't believe the tune or fuel delivery failure was a factor.
Old May 9, 2006 | 07:05 AM
Runnerdown's Avatar
Default Re: (swapdohc)
remember that #3 cylinder runs hottest in b-series.
Old May 9, 2006 | 08:56 AM
Natural Aspirations's Avatar
At 10 psi and 280 whp it is most likely your tuning is to blame for the failure. Look at the stuff Evans Tuning is able to pull off with stock blocks and manage to keep them together. What is the Block Bore?
Old May 9, 2006 | 01:28 PM
swapdohc's Avatar
Default Re: (crixzc)
Why would 280 whp @ 10psi point to a tuning problem? You need to take into considerstion that this was tuned on a Dyno Dynamics Dyno, which reads 14%-16% lower than our local Dynojet 224x, which would put the dynojet HP # around 320WHP. You also need to take into consideration that the compression is 9:1 which will yield a lower hp to boost ratio than a stock engine which is 10+:1 compression.
I have tuned many b-series cars and have had no problems at all, but NONE of them were block posted, this is why I am questioning the block posts. The cracks in the sleeve all start in the imediate area around the block post which tells me that the load created by the block post was too concentrated on the sleeve.
So please explain to me why the tune is suspect as I do not want to have this problem again.
Old May 9, 2006 | 06:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crixzc &raquo;</TD></TR><TR><TD CLASS="quote">At 10 psi and 280 whp it is most likely your tuning is to blame for the failure. Look at the stuff Evans Tuning is able to pull off with stock blocks and manage to keep them together. What is the Block Bore?</TD></TR></TABLE>
This wasnt a stock block. it was posted.
Old May 9, 2006 | 07:00 PM
stizzit's Avatar
A little detonation and boom ... the block posts will do nothing for you if you're detonating.
Old May 10, 2006 | 02:40 PM
vtecmissle's Avatar
Default Re: (stizzit)
And when the sleeve spreads the first line of pressure is going to be at the posts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stizzit &raquo;</TD></TR><TR><TD CLASS="quote">A little detonation and boom ... the block posts will do nothing for you if you're detonating. </TD></TR></TABLE>
Old May 10, 2006 | 09:05 PM
swapdohc's Avatar
Default Re: (vtecmissle)
I found the culprit!!!!
I got in touch with my machine shop and went over the build, it turns out that he over-torqued the block posts. He put them to 4 in/lbs instead of 2 in/lbs, believe it or not that was enough to crack the sleeve.
BTW I own a shop, own my own dyno and have tuned more Hondas than I can remember, there was no signs of detonation on the plugs, pistons, bearings or datalogs.
Old May 14, 2006 | 10:53 PM
oldskool teggy's Avatar
ouch, expensive mistake.. but its great that he admitted to it
Old May 15, 2006 | 06:45 AM
oscarmayer's Avatar
Stress fracture from over-torqued block posts and poor tuning, pure and simple.
Old May 15, 2006 | 07:30 AM
xerox445's Avatar
Default Re: (oscarmayer)
yeah, larry clearly states only 2 INCH pounds for the posts. Is the machine shop willing to reinburse you at all?
Old May 15, 2006 | 06:01 PM
where do you get poor tuning from?
AirbornManJuice
Jan 20, 2015 09:54 AM
EJ1_228
Mar 25, 2008 11:26 PM
fastboy559
Nov 3, 2007 06:00 PM
x91crxsix
Jul 28, 2006 10:42 AM
pbomers
Jun 30, 2002 06:41 AM
