valve lapping
Old May 2, 2006 | 09:20 AM
2k.civic.si's Avatar
Default valve lapping
after searching and coming up with only 4 threads on valve lapping in the archive i would like someone here who actually does honda heads for a living to explain the correct process for sealing a valve to the valve seat properly...
Old May 2, 2006 | 11:37 AM
dfoxengr's Avatar
Default Re: valve lapping (2k.civic.si)
get a valve lapping tool. and some dual grit sompund.
follow instructions on the back. basically put the heavier grit on, lap it some, and finish up with lighter grit.
really easy.
-derek
Old May 2, 2006 | 12:58 PM
Default Re: valve lapping (dfoxengr)
so ive read...would it help in anyway to say go to a 1000grit for the final lapping of the valve?
basicly just looking for any tips/tricks if there is any
Old May 2, 2006 | 01:19 PM
dfoxengr's Avatar
theres 2 grits in the jars you buy, use the heavy then the light. thats all. no tricks.
Old May 2, 2006 | 01:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">theres 2 grits in the jars you buy, use the heavy then the light. thats all. no tricks.</TD></TR></TABLE>
what grit you recomend...autozone has 110/220 and pepboys has 120/240 and i can also order pretty much anything around there up to 1200grit
Old May 3, 2006 | 12:04 AM
EnzoSpeed's Avatar
I liked the stuff I got at AutoZone. It had a grit that broke down as the valve was lapped in. So it started out super coarse and broke down into polish by the time the valve was finished. No need for multiple grits.
Old May 3, 2006 | 05:01 AM
dfoxengr's Avatar
Default Re: valve lapping (EnzoSpeed)
110 v 120 is basically the exact same, lol.
Old May 3, 2006 | 10:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">110 v 120 is basically the exact same, lol.</TD></TR></TABLE>
true but usually someone who has been doing heads for 20 years will have a preference for some reason...i just like lookin at all angles before i jump in
enzo...i think your talkin about the permatex stuff in the tube...ive heard it works well...guess ill have to try different ways over the years
Old May 3, 2006 | 03:00 PM
EnzoSpeed's Avatar
Yup, it's permatex. The only issue with it is that for moderate lapping, you have to keep aplying it because it breaks down into polish before you've lapped enough to get a good seal.
averyvm
May 21, 2007 08:06 PM
bb4socal
Nov 18, 2006 07:02 AM
95blackEG
Apr 25, 2006 10:28 PM
310BHPB16
Sep 6, 2005 08:27 AM
Shift_Fast
Feb 19, 2005 11:24 AM
