What is it?
Old May 1, 2006 | 01:00 PM
Walterronny's Avatar
Default What is it?
here say FLUID BRAKE DOT 3 DOT4 , but.. i think that could be about ABS.. or what is it?
besides when i lower below car i see it..
it is close that axle
i found thus.
what is it?
Old May 1, 2006 | 02:36 PM
thesmogman's Avatar
Default Re: What is it? (Walterronny)
The hose you are pointing to is an overflow for your carbon cannister.
As for the brake fluid thing Not sure in that area could be ABS, or could be clutch master cylinder but the clutch is usually over by the brake master cyl.
So my answer is ABS
Old May 1, 2006 | 04:17 PM
rainforest's Avatar
Default Re: What is it? (thesmogman)
abs modulator/reservoir.
Old May 2, 2006 | 01:07 AM
redsikiller's Avatar
Default Re: What is it? (rainforest)
use dot3, as far as I know. If your car is a civic, it works for both brakes and clutch as the manual instructs.
Old May 2, 2006 | 07:45 AM
really? work for both? my car is a civic yeah.. thank you..
Old May 2, 2006 | 10:38 AM
__oversea's Avatar
it says on the tag on the tank. use only dot3 or 4. brake fluid
Old May 2, 2006 | 11:31 AM
but then ? there are two tank for brake fluid? (the other is that goind with brake booster)
Old May 2, 2006 | 07:00 PM
Default Re: (Walterronny)
use dot3 for both. No problems
Old May 3, 2006 | 05:05 AM
JimBlake's Avatar
That reservoir under the battery is for the anti-lock brakes. Use the same brake fluid as your main brakes & clutch.
Old May 3, 2006 | 10:03 AM
thank you brothers
Declectic
Apr 4, 2014 03:20 PM
LordAphotic
May 31, 2011 06:06 AM
i97supratti
Apr 9, 2011 10:42 AM
94eg!
Jun 28, 2007 07:14 AM
MikeTV
Aug 5, 2003 02:23 PM
