Oil Pressure, WTF?
Old May 2, 2006 | 02:59 PM
AccordDX89's Avatar
Default Oil Pressure, WTF?
I just went through the pain in the *** process of replacing bearings. I plastigaged everything and came up with .0015". That's within spec. My oil pressure is still low. I don't know what the hell is going on but I'm getting pissed. My oil pump only has around 6K miles on it. Is it going bad already? How can I check before buying a new pump? BTW, I have an Autometer mechanical oil pressure gauge but there is air in the line. Is that causing bad readings?
Modified by AccordDX89 at 7:10 PM 5/2/2006
Old May 3, 2006 | 01:42 PM
MajorPayne's Avatar
Default Re: Oil Pressure, WTF? (AccordDX89)
If you are sure there is air in the line i would definitely fix that first, the air will compress when the pressure goes up, which is probably giving you the low reading
Old May 3, 2006 | 04:54 PM
AccordDX89's Avatar
Default Re: Oil Pressure, WTF? (MajorPayne)
Any ideas how to do that? I didn't anything about bleeding the line in the directions from Autometer.
Old May 3, 2006 | 04:56 PM
MajorPayne's Avatar
the only thing i can think to do is get the gauge out of the car, hold the line up vertically and fill the tube with oil, maybe move it around a bit to get the air bubble to work its way out to the top, thats the only thing i can think of, ive never really encountered that problem before
Old May 3, 2006 | 07:42 PM
Chiovnidca's Avatar
How much pressure does it have? Say at idle and about 3k. The air in the line isn't going to hurt anything.
Old May 3, 2006 | 08:23 PM
adictionbass's Avatar
Default Re: Oil Pressure, WTF? (Chiovnidca)
im in the same boat as you with my built GSR. Im running a mechanical and electrical gauge to make sure the reading is correct. You havent posted your numbers, but im at 10-15 at idle, and 50 at 3k and up... 10w30 oil
Old May 4, 2006 | 03:49 AM
AccordDX89's Avatar
Default Re: Oil Pressure, WTF? (adictionbass)
Mine is reading a little over 0 at idle and 30 at 3K. There is a substantial amount of air in the line. I'm talking like a 6" section of the tubing is just air.
Old May 4, 2006 | 08:25 AM
hmmm... When my car is off, most of the oil seems to drain out of the mechanical line anyway. As soon as i turn the car on, it all pressurizes with oil
Old May 4, 2006 | 02:16 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordDX89 &raquo;</TD></TR><TR><TD CLASS="quote">Mine is reading a little over 0 at idle and 30 at 3K. There is a substantial amount of air in the line. I'm talking like a 6" section of the tubing is just air.</TD></TR></TABLE>
Have you had the head off? Was the oil control jet installed? (if your uses one)
Old May 4, 2006 | 02:33 PM
MajorPayne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Have you had the head off? Was the oil control jet installed? (if your uses one)</TD></TR></TABLE>
that would definitely do it also.... air in the line "shouldnt" cause a problem, but if theres nothing else he can think of, id try and get the air out as much as possible
Old May 4, 2006 | 03:27 PM
AccordDX89's Avatar
I did have the head off and the oil control jet was in the block when I put it back on. If that's the one you're talking about. This is a B16, BTW. I just had the car running a few mins ago and I can watch the oil in the line bouncing back and forth with the air in the line. I don't see how it can be close to accurate doing that. The gauges sits a 0 at idle but my idiot light doesn't come on. I e-mailed Autometer about it and they said if I bleed it, when I turn the car off, the oil will just all drain back out again.
Old May 4, 2006 | 03:32 PM
MajorPayne's Avatar
and you installed it correctly and in the proper place? somethings not right
Old May 4, 2006 | 04:00 PM
AccordDX89's Avatar
Default Re: (MajorPayne)
On the back side of the block between cylinders 2 and 3? It's pushed in flush with the top of the gasket surface.
Old May 4, 2006 | 04:26 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordDX89 &raquo;</TD></TR><TR><TD CLASS="quote"> The gauges sits a 0 at idle but my idiot light doesn't come on. </TD></TR></TABLE>
Did you use a "T" fitting for the gauge and dummy sender? Did you put a new gasket on the oil pickup? Quit worrying about the air in the line!!!
Old May 4, 2006 | 04:45 PM
AccordDX89's Avatar
I have that. A new gasket was used on the oil pickup.
Old May 10, 2006 | 02:53 PM
AccordDX89's Avatar
Can someone help here or do I need to rip my engine out again?
Old May 13, 2006 | 08:10 PM
LSVTEC 91 Civic's Avatar
Banned
Check oil pickup, oil pump
Old May 14, 2006 | 08:38 AM
Brick Top's Avatar
Default Re: Oil Pressure, WTF? (LSVT3K 91 C1V1C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C &raquo;</TD></TR><TR><TD CLASS="quote">Check oil pickup, oil pump</TD></TR></TABLE>
my oil pickup was smashed against my pan when i got low oil psi readings. but the pan was fine. i think 1.8 pickup needs to go with 1.8 pan etc etc...
JDM_SOHC
Jan 4, 2008 11:48 AM
drSquish
Oct 16, 2005 02:30 PM
Tage Evanson
12
Jul 22, 2005 09:24 PM
sporkcrx
Oct 10, 2003 09:28 AM
