reusing my stock head studs???
Old May 1, 2006 | 10:36 PM
gabrielle's Avatar
Default reusing my stock head studs???
i have just finished rebuilding my type r motor. Motor only has 60k on it and i was wondering if i can resuse the same head studs becuase i miled the head .010 lmk . If i use the headstuds again what should i use to seal the threads talking about lock tight,sealant, or anything like taht.
Old May 2, 2006 | 11:34 AM
ccivic's Avatar
Default Re: reusing my stock head studs??? (gabrielle)
Shouldn't reuse stock headstuds-- get some ARPs or AEBS.
Old May 2, 2006 | 11:40 AM
dfoxengr's Avatar
Default Re: reusing my stock head studs??? (ccivic)
nope
and you come stock with headbolts.
Old May 2, 2006 | 07:38 PM
gabrielle's Avatar
Default Re: reusing my stock head studs??? (dfoxengr)
not answering my question. has anyone used there stock head bolts again and if so have u had any problems with them
Old May 2, 2006 | 08:20 PM
bigizsosexy's Avatar
Ya you can, but if you have the money to buy the ARP's do so, but if your broke then reuse them, I suggest the ARP's
Old May 2, 2006 | 10:26 PM
Ls1 FD3s's Avatar
Default Re: reusing my stock head studs??? (bigizsosexy)
Ive reused them 4 times with copper spray, never a problem...
I always put everything to the test!!!
Old May 2, 2006 | 11:59 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: reusing my stock head studs??? (Ls1 FD3s)
I've reused the bolts on my old B16 before, but i would still recommend new bolts.
Old May 4, 2006 | 05:50 PM
boostedblkef's Avatar
Default Re: reusing my stock head studs??? (JDM_Ej)
look to see if there streched before you reuse them i dont recomend it but you can but just buy arps
EFstyle
Nov 2, 2008 11:30 AM
bigplayj17
Aug 15, 2007 09:07 PM
boostin4door
Jan 22, 2005 05:23 AM
aira
10
Jun 13, 2003 01:12 AM
schwett
Apr 18, 2002 03:43 PM
