pistons/wall clearance
Old May 3, 2006 | 08:16 PM
2k.civic.si's Avatar
Default pistons/wall clearance
how loose can you run the clearances?
cylinder measers 3.198 and pistons measure 3.1914
im thinking .0066 is a bit to loose
granted this is a beater turbo motor
Modified by 2k.civic.si at 5:30 AM 5/4/2006
Old May 4, 2006 | 04:04 AM
NJIN BUILDR's Avatar
Default Re: pistons/wall clearance (2k.civic.si)
It matters what piston your talking about.A Ross piston will work at that clearance,but a SRP will make alot of noise when its cold.
Glenn
Old May 4, 2006 | 09:04 AM
Default Re: pistons/wall clearance (NJIN BUILDR)
oem cast pistons...thought they ran tighter clearance then forged so i figured i would ask
Old May 4, 2006 | 03:22 PM
ppfalcon's Avatar
I will say this I ran vitaras which run a little loose and had my rings gaps on the wide side, now I am having to pull the bottom end apart because something is screwed..so be careful blow-by will not hurt alot on a NA motor but on a turbo it will rob you of power and damage your turbo..
Old May 4, 2006 | 04:45 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">oem cast pistons...thought they ran tighter clearance then forged so i figured i would ask</TD></TR></TABLE>
That's way too much for stock pistons.
Old May 4, 2006 | 07:26 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">oem cast pistons...</TD></TR></TABLE>
thats WAYY to much clearance for cast pistons...
Old May 4, 2006 | 07:41 PM
Default Re: pistons/wall clearance (non-VTEC)
ill just order oversized then...more work...bah
team2dcrx
Jul 28, 2015 03:39 PM
.adam.
Nov 21, 2007 02:39 PM
CivicVX94
Nov 23, 2006 05:59 PM
Chillinit
Apr 24, 2005 09:04 AM
