want to try ENGINE RESTORER
Old May 2, 2006 | 04:42 PM
ludaboy93's Avatar
Default want to try ENGINE RESTORER
My h23 has 190 000km and i wanted to use an engine restorer on my next oil change. i dont want to use the sea foam method either. Can anyone recommend a product?
Old May 5, 2006 | 08:02 AM
devnull's Avatar
Having experience with Entine Restore it is an okay product, however it's effects are short term and may only mask your true problems. Since to "revitalize" your engine I would recommend running an oil flush product before you drain for 5 minutes. Then use a thicker weight oil, up one weight should suffice (10w-30 to 10w-40).
Also you might want to check spark plugs and get a valve lash job.
Old May 5, 2006 | 09:58 AM
Lsos's Avatar
Default Re: want to try ENGINE RESTORER (ludaboy93)
A friend used engine-restore in his tired old engine. The engine blew up the next day. Hole right in the block.
devin0606
Mar 21, 2017 12:45 PM
fragmare
10
Sep 10, 2012 08:23 PM
DeDonDeRosa
Apr 11, 2003 10:48 PM
_Endless_
Feb 27, 2003 07:37 AM
