Chipped ECU boost options
Old May 5, 2006 | 09:36 AM
Qveon's Avatar
Default Chipped ECU boost options
Im fluent with an e-manage which i can make have a 16x15 table for boost fuel adding and igntion timing (obviously change in percents to the ECU's stock map), but i was looking at uberdata and crome and the boost tables are 6x20. How is 6 columns enough resolution for tuning or am i missing a way to make more boost columns? It seems weird that like on an 11psi setup the table jumps from like 0.3psi to 1.13 to 3.45 to 5.78. how can all that area inbetween values be "good" for tuning?
Old May 5, 2006 | 09:40 AM
devnull's Avatar
6x20??? I don't think so. If you mean there is only 6 tables for boost than click on the value in the box (header, box that displays the boost value). You can change those.
Old May 5, 2006 | 09:54 AM
Qveon's Avatar
just a sec let me grab a pic
Old May 5, 2006 | 10:03 AM
Qveon's Avatar
Default Re: (Qveon)
See i can use everything right of the red line for boost, but on the e-manage i can use the whole table cause i can set the values how i want, but how i can i add more columns to the right of the arrow using uberdata or crome? Or is there an explanation that i dont need more columns?
( I am using a JRSC on a h22 if it matters )
Old May 5, 2006 | 10:18 AM
devnull's Avatar
That looks like uber. I'm not sure 100% about uber but i think you can click on 1.13 and change the value. You can also do that down the line for in/HG.
Old May 5, 2006 | 10:28 AM
Qveon's Avatar
Default Re: (devnull)
yea but then i am taking away from the not boosted maps. Is there a way to just add more columns to the whole table?
sanman000719
May 28, 2013 06:33 PM
BoostinTEG
Engine Management and Tuning
May 1, 2011 01:53 PM
aalb1
Nov 15, 2005 02:09 PM
nigel
Mar 24, 2004 05:29 PM
HotRodTeg
Sep 9, 2003 10:52 AM
