Immobilizer swap?
Old May 6, 2006 | 12:42 PM
milano2kdc2's Avatar
Default Immobilizer swap?
Hello, I have a 2000 gsr and I want to use a P73 (Type-R) ecu to past smog. The immobilzer on the P73 ecu has been removed, desoldered by the previous owner. The problem is that the P73 ecu throws the immobilizer check engine light, and I don't think I can pass like that.
To my understanding the immobilzer is the chip on the left pictured here:
Now, pictured here is the P72 (gsr) on the left and P73 (type-r) on the right.
Can I solder in my gsr immobilizer chip onto the P73 board? (therefore use my stock gsr key with no check engine light?)
Old May 6, 2006 | 04:36 PM
H2290's Avatar
Default Re: Immobilizer swap? (milano2kdc2)
Not 100% sure but I don't think you would throw any codes if you just swapped the ECU. Just drive it really lightly to the shop.
Old May 6, 2006 | 05:44 PM
B2FiNiTY's Avatar
Default Re: Immobilizer swap? (H2290)
You will have CEL once you remove the imo. like it says.
Old May 6, 2006 | 07:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2290 &raquo;</TD></TR><TR><TD CLASS="quote">Not 100% sure but I don't think you would throw any codes if you just swapped the ECU. Just drive it really lightly to the shop.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">You will have CEL once you remove the imo. like it says. </TD></TR></TABLE>
i'm not asking if i'll throw a code or not, i'm asking if the immobilizer chip from the gsr ecu will work in the itr ecu
Old May 7, 2006 | 11:29 AM
CaptinMcnut
May 16, 2006 05:15 PM
milano2kdc2
May 15, 2006 10:57 PM
DC2SIR-G
Feb 15, 2006 09:31 AM
tallguy
Dec 1, 2005 08:25 AM
TurboRedSi
Jul 17, 2003 10:59 PM
