Timing belt: Is this normal?
Old May 4, 2006 | 05:19 AM
B18C_EJ8's Avatar
Default Timing belt: Is this normal?
Pulled my valve cover last night to check things over, and saw that my timing belt was a little weird looking. Is this normal for the belt not to be centered?
Old May 4, 2006 | 05:24 AM
snatch's Avatar
Default Re: Timing belt: Is this normal? (B18C_EJ8)
It looks a little off. How long has it been since the belt has been changed/removed/messed with? Mine is a little off center, but certainly not that much.
You could check everything out release the tension, try rec-entering it then re-tensioning it. Or you could just leave it and check it again every so often; see if it changes.
Old May 4, 2006 | 05:38 AM
B18C_EJ8's Avatar
The car just got running about a month ago, so that was when it was installed. The car is going back to the shop in 2 days for a slight tuning adjustment and valve adjustment so I'll have them check it out.
Old May 4, 2006 | 05:58 AM
snatch's Avatar
Default Re: (B18C_EJ8)
That would be a good idea. Get a second opinion on it.
Old May 4, 2006 | 12:33 PM
b20vtech's Avatar
just push it back in......
Old May 4, 2006 | 01:25 PM
thesmogman's Avatar
Default Re: (******)
Did you install the sprockets? are they on wrong as in did you flip them over?
Just a thought.
Old May 4, 2006 | 01:41 PM
havok hybrid's Avatar
Default Re: (thesmogman)
There are to washers that are installed down on your crank gear.. one in back of the gear and one in front.. I have seen belts walk when.. the washers are installed wrong.
The washers have a dome shape to them.. both the dome sides needs to face the belt .. that will keep the belt in the center of the gear at all time.?
did that help at all
bfeils
Mar 24, 2007 10:20 AM
bb_one
Jul 7, 2006 09:20 AM
Eg692Si
Sep 14, 2004 11:10 PM
KingJeff
Aug 10, 2004 02:53 PM
integrasi
Oct 30, 2003 08:12 PM
