reinstalling Head tips and pointers also Rear Balance Shaft Ques
Old May 8, 2006 | 06:08 PM
SrT4u2nV's Avatar
Default reinstalling Head tips and pointers also Rear Balance Shaft Ques
when reinstalling head, timing belt, water pump, tensioner and rear balance shaft pulley do u have to adjust it to TDC? I read some where thats there's a bolt in the back of the engine that holds the shaft of the rear balance shaft and it has to be turned to TDC and then reinstall the pulley. Also is there any pointers that i can be helpful. Im worried about timing as usual and valve lash adjustment. I know how to do it i just never have done it before so pointers are appreciated.
Edit: Sorry its an H22A
Researched So Far:::
the key on the crank pully is the same as lining up the flywheel. just line the key on crank with the tdc mark on the engine. then match the cam gears (arrows up and 2 notches in line). then for the balance belt use the back service hole to get the rear balance pully at tdc. get a 4 inch screw and mark it at 2.9 inches stick it in the service hole to lock it at tdc. then line the mark on oil pump with mark on engine. then your done
Modified by SrT4u2nV at 2:54 AM 5/9/2006
Modified by SrT4u2nV at 6:06 PM 5/9/2006
Old May 8, 2006 | 06:23 PM
Stoich EG2's Avatar
Default Re: reinstalling Head tips and pointers also Rear Balance Shaft Ques (SrT4u2nV)
what engine is this? i can give you pointers on how to install LS1 heads?
Old May 9, 2006 | 01:54 AM
SrT4u2nV's Avatar
moRninG bUmP!
Old May 9, 2006 | 02:20 PM
SrT4u2nV's Avatar
aNyOnE?!?
Old May 10, 2006 | 02:10 AM
SrT4u2nV's Avatar
gOOdmOrNinG bUmP!!!
Old May 11, 2006 | 02:15 AM
SrT4u2nV's Avatar
tTt!!!
Old May 11, 2006 | 04:16 PM
SrT4u2nV's Avatar
LaTe DaY bUmP!!!
Old May 13, 2006 | 06:32 AM
SrT4u2nV's Avatar
aNyOne!?! noBoDy
Old May 14, 2006 | 04:33 PM
SrT4u2nV's Avatar
tTt!
Old May 15, 2006 | 09:33 AM
gents97civ's Avatar
just cut the belt for the balance shaft, it isnt needed
asinclado
Mar 19, 2016 08:52 AM
kornerk12
Nov 16, 2008 08:10 PM
dge330
May 21, 2008 08:56 AM
afreeclimber
Apr 8, 2008 10:45 AM
SrT4u2nV
May 16, 2006 02:43 PM
