clutch??? is this ok? help please!!
Old May 4, 2006 | 01:54 PM
midnitesol's Avatar
Default clutch??? is this ok? help please!!
[IMG][/IMG] how do i post pics????
Old May 4, 2006 | 03:58 PM
thesmogman's Avatar
Default Re: clutch??? is this ok? help please!! (midnitesol)
You have to have it like this...
[IMG]http://www.?????.com/image location/imagename[IMG]
Old May 4, 2006 | 11:56 PM
midnitesol's Avatar
Default Re: clutch??? is this ok? help please!! (thesmogman)
hope i get it right
there are about 2 of these indentations on it is it fine or should i replace it?
Old May 5, 2006 | 12:00 AM
midnitesol's Avatar
one more try
Old May 5, 2006 | 12:05 AM
midnitesol's Avatar
Old May 5, 2006 | 12:07 AM
midnitesol's Avatar
cant get it but there are two indeentations on the part of the clutch assembly that bolts up agaianst the tranny. not sure if this explains it but n e info will help. thanx ahead of time!
Old May 5, 2006 | 12:17 AM
rbanke's Avatar
heres your pic.
It looks ok to me, which part were you worried about?
Old May 5, 2006 | 12:26 AM
midnitesol's Avatar
Default Re: clutch??? is this ok? help please!! (rbanke)
sweet dont know how u did it but thanks
i was worried about the indent directly to the right about 2 inches of the green marking
Old May 5, 2006 | 12:32 AM
rbanke's Avatar
well its hard to tell how bad of a dent it is. the question is, was this originally on the car, you pulled the tranny and saw this? or is this a used part that could have allways been this way. Either way if it was driving fine, then it should be ok as it would be just cosmetic.
Old May 5, 2006 | 12:39 AM
midnitesol's Avatar
well i pulled the tranny and saw this but i busted my transfer case so im not sure. would would cause an indentaion there?
Old May 5, 2006 | 12:45 AM
rbanke's Avatar
broke it while removing it or while driving. if it was while driving, you can bet the dent is from whatever broke off. if it broke while driving, was the clutch still operating afterwards? if so, then the dent wont hurt you....but find the broken piece of your case
Old May 5, 2006 | 12:50 AM
midnitesol's Avatar
it broke while driving luckily in my driveway so i did find the piece and my clutchwas still working so hopefully im good to go! oh and i ordered a ctr tranny so ill probably get rid of my b16 trans. thanx for your help! oh and how did u get the pic to work?
Old May 5, 2006 | 01:13 AM
rbanke's Avatar
if everything seemed to be ok, i wouldnt think twice about it, its just a ding.
Well, i looked at the links you tried to post and in a round about way found the pic. the way to post them is to get the url of the picture. you can right click a picture and choose properties, the 'address' is what you need to copy and put between the [img][/img] brackets
Old May 5, 2006 | 05:35 AM
Umm1.8t's Avatar
put the link to the pic inbetween the
Old May 5, 2006 | 07:36 AM
midnitesol's Avatar
sweet thanx, i was just not gettin it. my ctr tranny should be here today so hopefully everything works fine!!! once again thanx for everything!
*Boostwerks*
Apr 16, 2002 08:11 PM
juicy.koreans.suck
Dec 21, 2001 10:53 AM
