turn signals help
Old May 7, 2006 | 10:33 AM
d0nk1llum1nati's Avatar
Default turn signals help
I drive a 2001 integra and my signals wont work right. I put a new fuse in and re wired the wires. They only blink when my hazards are on, and the signal lights on the gauge cluster only works when I turn my hazards on. So yea, I can't signal left or right..... can someone please help me?
Old May 7, 2006 | 02:56 PM
Default Re: turn signals help (d0nk1llum1nati)
no one knows?
Old May 8, 2006 | 06:23 AM
suspendedHatch's Avatar
Why did you rewire them. What was the problem originally?
The procedure for checking the switch is in the Haynes manual. That's how I troubleshooted and then replaced the parking light switch on my friend's mom's Civic.
Old May 8, 2006 | 11:55 AM
Default Re: turn signals help (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Why did you rewire them. What was the problem originally?
The procedure for checking the switch is in the Haynes manual. That's how I troubleshooted and then replaced the parking light switch on my friend's mom's Civic.</TD></TR></TABLE>
I rewired them beacause I recently just put sidemarkers on. At first I thought something was wrong with my wiring. I think my uncle has that manual. I'll check it out. thanks
Old May 8, 2006 | 04:54 PM
rainforest's Avatar
if you dident do something when wiring the signal the absolute fist thing i would check is the combonation switch (the **** that selects what turn signal turns on) because the same relay powers the signals but will bypass the combo swich if only the hazar swich is on. basiclly if the hazard switch was bad there woul be no signals at all and if the relay was bad it would do the same thing.
amit_b82
10
Mar 2, 2008 08:39 PM
irishhonda
Feb 19, 2008 04:55 PM
Jussstin
22
Apr 21, 2007 10:06 PM
dajoyner
Jun 18, 2006 11:23 AM
Special-K-Coupe
May 20, 2005 10:03 PM
