Problems with 97 Civic EX w/ E-manage - error code 11
Old May 7, 2006 | 09:33 AM
EKhothatch's Avatar
Default Problems with 97 Civic EX w/ E-manage - error code 11
Everything is wired up correctly according to this diagram.
Turbo D16 E-manage OBDII
Also, I had E-manage on my 96 Civic with has since been removed but I have double check against my wiring harness and it is correct.
I'm getting a error code 11 on the E-manage when the car is started. Greddy's manual says its:
Error Codes
"Incorrect wiring or disconnected Airflow Signal 1"
I have wired the MAP in correct to it. Both through RED/GRN and through GRN/WHT, and were still getting the code. What else could I check or could be causing the problem? Could the E-manage be set-up incorrectly? It's pre-programmed so I don't think thats it.
Thanks.
Shane
Old May 7, 2006 | 10:38 PM
EKhothatch's Avatar
Default Re: Problems with 97 Civic EX w/ E-manage - error code 11 (EKhothatch)
Nevermind.
Fixed.
nkuser
Nov 20, 2020 08:36 PM
Pak Lang
Feb 25, 2017 05:51 PM
BoostedSiRhc
Dec 12, 2005 10:32 PM
slowpoke792
Dec 8, 2005 02:07 PM
reaction360
May 10, 2003 03:53 PM
