Cooling Fan wiring
Old May 3, 2006 | 09:00 PM
cycloneb18c3's Avatar
Default Cooling Fan wiring
Ok I have a 91 Integra. I want to wire up my cooling fan, and I do not want to use any of the existing wiring or relays. I want to have a switch so I can turn it on manually when ever the ignition is on, and I also want to be able to have the motor kick it on when it needs it.
Heres a diagram I came up with:
The problem with this one is that there is no way for the ECT switch to be incorporated.
So I came up with this. Im not sure if the wiring is going to the correct poles on the relay either..
thanks in advance for any help you may be able to give.
Dan
BB6-213
Aug 2, 2011 07:35 PM
Sean @ ESG
Mar 21, 2011 10:17 AM
harmonator84
Feb 18, 2007 09:34 AM
HxCforever
Mar 10, 2006 05:52 PM
Sick79
Jan 18, 2005 09:02 AM
