Changed dizzy, now car is slow
Old Mar 13, 2010 | 08:09 PM
category5 SI's Avatar
Default Changed dizzy, now car is slow
Had to change dizzy on my b16 and now it is noticeably slower then before. It runs fine,idles good it just doesn't pull like it did before. What could have caused this?
Old Mar 13, 2010 | 10:20 PM
talonboy1991's Avatar
Default Re: Changed dizzy, now car is slow
Check your ignition tinming if you hadn't done so already and what were the causes of the dizzy swap ?? Most likely its just the ignition timing off a lil bit
Old Mar 13, 2010 | 10:31 PM
The crank angle sensor went out. how do I check the ignition timing?
Old Mar 13, 2010 | 10:38 PM
I'm not entirely sure on a b16 I know tht you can just do it by ear on d series by turning the dizzy either back or foreward to advance or retard the ignition timing you can prolly just adjust the cas I'm not really sure on a b16 like I said bc before my del sol I was a dsm guy not much experience with honda
Old Mar 13, 2010 | 10:41 PM
Thanks.maybe I'll try that.
Old Mar 14, 2010 | 11:35 AM
Turned the dizzy foward just a hair and that did it. I have vtec again and all is good.
Old Mar 14, 2010 | 04:45 PM
mouab18c1's Avatar
You need a timing gun to check your ignition timing.
jdmasfuk
Jul 15, 2010 07:06 AM
riS.I.R
Nov 13, 2009 04:38 PM
peel17
Jan 23, 2006 02:30 PM
ApolloSpeed
May 19, 2005 11:27 AM
