90 Civic Dx overheating problem
Old Mar 31, 2010 | 10:38 AM
speaksangel's Avatar
TRIAL USER
Default 90 Civic Dx overheating problem
Hey guys,
I'm relatively new at this DIY vehicle maintenance, so I'm not sure as to what in the world is going on. Here's the problem (or should I say problems) that I am having. I have a 1990 Civic Dx that I bought from a friend. It started overheating so I tried to find out what the problem was. I noticed that there was a small crack at the top of the radiator where the antifreeze was spewing out of... sorta like a massive volcanic eruption. I managed to get that fixed but it is still overheating. It takes 5- 10 minutes for the vehicle to warm up, but when it does the hot and cold gauge blows it's top off.I start thinking maybe it's the thermostat. The top hose gets hot, but the lower hose remains cold. The next problem that I was running into was the fact that the engine seems not to be getting power. It drives along fine for a while, then all of a sudden when you press the gas pedal it doesn't want to go anywhere. It stumbles for a little bit then it picks up speed as if nothing were wrong, until you stop the car again. I thought it may be time for new spark plugs... I don't know....Someone please help...
Nala
Old Mar 31, 2010 | 11:44 AM
dpetro1's Avatar
Default Re: 90 Civic Dx overheating problem
how did you "fix" the radiator? the only fix i know would be to replace it since honda use plastic end tanks.
also you need to replace the thermostat. if the lower hose never warms up thats a sign that the thermostat is stuck closed.
Old Mar 31, 2010 | 06:02 PM
fcm's Avatar
fcm
Old Fart
Ditto all the above^^^ 94
Old Apr 1, 2010 | 04:08 PM
ef9ridda's Avatar
sounds like a thermostat but i would just invest in a 10 dollar thermostat and then 50 (or so)on a new radiator... and see what happens as far as your power loss issue i would check the map sensor or vacuum leaks, do you have a check engine light on?
MaterialSense
Honda Civic (2001 - 2005)
Jun 21, 2019 09:03 AM
speaksangel
Apr 3, 2010 03:10 AM
user 69782342442
Classic Hondas
Feb 19, 2009 11:51 PM
Missouri_Civ
Jul 9, 2007 04:14 PM
Undertaker1064
Jul 11, 2006 02:07 PM
