piston and bore size
Old Mar 14, 2010 | 01:23 PM
hYbRid_Eg6's Avatar
Default piston and bore size
ok I dropped a valve couple months ago, but before I bought pistons, I took the block to the machine shop to see if the block can be bored out to 85.5mm, it was at 85mm, so i had it bored without the pistons, it cleaned up all the nicks and dings, now my question is, am I going to problems if i bought CP pistons with the bore size at 85.5mm will the clearance be a problem or will i be ok?
Old Mar 15, 2010 | 05:57 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: piston and bore size
errr....what motor is this your talking about?
Old Mar 15, 2010 | 07:12 AM
hYbRid_Eg6's Avatar
Sorry it's a sleeved gsr block.
Old Mar 15, 2010 | 07:15 AM
I'm not Rick!
jus make sure you have the correct head gasket and the combustion bowl in the head match the block (while porting, usualy they ask you what size the bore is.)
Old Mar 15, 2010 | 02:20 PM
hYbRid_Eg6's Avatar
I'm talking about the piston spec, before you bore out the block you have to have the piston first, depending of what piston you get right? I heard that CP pistons you dont have to have the pistons on hand when you bore out your block is that true?
Old Mar 15, 2010 | 03:23 PM
kyden's Avatar
no machine shop should ever bore out a motor without the pistons being there.
Old Mar 15, 2010 | 11:24 PM
hYbRid_Eg6's Avatar
not always the case! got some info, the machine shop will bore a block whatever size you want it, all depends what piston you use, some pistons like CP and Arias include the wall clearances and some like JE and Wiseco do not, these are the one that the machine shop needs before they bore. and yes it is always better to have the pistons on hand, but in some cases the block gets dings from a droped valve and you just want to check if the block can be saved before you order any pistons.
Old Mar 16, 2010 | 07:40 AM
CerealKiller's Avatar
Both are correct.
I believe you just need to make sure that your clearance is still with in spec.
raverx3m
Jun 10, 2014 10:55 AM
stocker2shocker91
13
Oct 17, 2007 09:33 AM
MatHadder
Oct 1, 2006 05:59 PM
fastcivicboy
Mar 21, 2005 08:51 AM
speedy108
Nov 25, 2002 07:24 PM
