B20vtec compression test
Old Mar 27, 2010 | 01:09 AM
civic-one's Avatar
Default B20vtec compression test
HI i recently did a compression test on my b20block with b16 head. The results are
1 ..... 200
2 ..... im worried about this one 145
3 ..... 198
4 ..... 200
Does all these numbers have to match or was the guy who did my compresion test messing around with me. I was the one cranking in the car thats why and he was just telling me the numbers to write down. Also im kinda worried about number 2 which is 145 what can be done to make this catch up to the rest . . . valve grind my guess but more input would be nice. Was this guy serious with or he is just after the money. Let me know what to do.
Old Mar 27, 2010 | 03:15 AM
non-VTEC's Avatar
Default Re: B20vtec compression test
you need to find out why that one cylinder is low. you need to do a leak down test to find out where you are loosing compression.
Old Mar 27, 2010 | 04:35 AM
civic-one's Avatar
So leak down test first and then pull out head then do valve grinds.
Old Mar 27, 2010 | 01:51 PM
non-VTEC's Avatar
i suppose.....if that cylinder is down on compression it's either a bad valve/sealing issue or a piston ring issue....it's gotta come apart anyway.
Old Mar 27, 2010 | 01:55 PM
civic-one's Avatar
okay it is comin apart anyways.. imma upgrading pistons and I might as well remove head and redo everything i was planning to port polish too.
Old Apr 6, 2011 | 08:02 AM
b20vtec91DA's Avatar
could be as easy as valve adjustment or carbon build up but if just adjustment, you dont have to touch the head. i recommend leakdown test before you jump to conclusions. but if u yank it, might as well yank it and put pistons in it
KYDelSol
Mar 28, 2013 03:16 PM
humboldt_skim
May 31, 2008 08:18 AM
94_civic_tuner
Oct 10, 2007 02:00 PM
dreamreaperx
Dec 20, 2006 02:01 PM
EF8_SiR
Jul 20, 2003 10:24 PM
