Help Possible clutch problem?Idk
Old Mar 14, 2010 | 08:56 AM
EJ6JON's Avatar
Default Help Possible clutch problem?Idk
OK so I just swapped my del sol put a jdm b16 into it.. Well when the car is in the air the front tires spin but when on the ground the car wont move anywhere.I was told it could be the clutch was installed wrong I have no clue so I come to u guys to let me know what it could be..... I dont know if I make much sense but lmk if anything thanks guys
Old Mar 14, 2010 | 09:00 AM
S2Integra's Avatar
Default Re: Help Possible clutch problem?Idk
Odd problem, but he may be right. Clutch was probably installed wrong so that only a little power is transferred, but any load will cuase is to slip imensely. I think it centers around the clutch.
Old Mar 14, 2010 | 09:11 AM
EJ6JON's Avatar
well the car dosnt move at all on the ground so I cant tell if its even engaging its very confusing
Old Mar 14, 2010 | 09:17 AM
S2Integra's Avatar
I do not know thew intracacies of the clutch and transimission, but when my clutch slipped, the car hardly accelerated when I hit the padel and the engine revved quickly. I assume that it was transmitting some power. I resolved it by replacing the clutch. I would imagine that a clutch could slip when any decent amount of power is applied to the wheels, or more accurately torque. Maybe the friction dics just aren't grabbing for some unknown reason, but you may have to reinstall or determine if the clutch itself has failed. But I have a feeling it is simply to do with the clutch.
Old Mar 14, 2010 | 01:46 PM
EJ6JON's Avatar
anyone else think the same?
Old Mar 15, 2010 | 07:28 AM
EJ6JON's Avatar
ttt
Old Mar 18, 2010 | 10:25 PM
tmzcivic's Avatar
It may be the axles. If the axle splines aren't completely into the mating splines in the trans the tires will turn when its in the air, and not move under throttle when on the ground (trans spins but isn't "connected" to the wheels.
tscook3
Apr 26, 2014 02:58 PM
jdmposer
Apr 30, 2009 12:56 AM
DANgerous
Apr 4, 2004 01:37 PM
92 ex-r
Jan 8, 2004 11:15 AM
SilverS
Feb 26, 2002 02:21 PM
