OBD0 EG Hatch?
Old Mar 21, 2010 | 12:22 PM
Guga's Avatar
Icon3 DPFi to MPFi EG4 - Some questions, lots of pics and one vid now helpp
I thought that all egs (or honda past 92) was obd1, but my eg, d15b2 lsi engine, DPFI, has obd0 plugs at ECU, that green one and the two blacks...
Just like this:
http://www.marklamond.co.uk/tech-hon...-connector.jpg
I was planning on swapping a d15b sol manifold i have here to make it mpfi, and i also have a obd1 p08 ecu from the same d15b sol, and whats my surprise when i found out it is obd0
What are my chances? Whats the best way of going to fit the manifold there? Can i still use the obd1 manifold (cuz i have it complete with TB, injectors, raill etc) with the obd0 arness and ecu just by adding and switching some wiring?
Old Mar 21, 2010 | 03:33 PM
94EG8's Avatar
Seagull Management
Default Re: OBD0 EG Hatch?
That was more of a north american thing. European stuff is a little different, they had carburated EGs in some cases.
Old Mar 21, 2010 | 03:44 PM
Guga's Avatar
lol damn
so im cutting my ecu connectors and jumping some obd1 connectors, will i be ok using a p08 from a d15b `?
Will the car start if i just follow the schemes on the forum to make the obd0 to obd1 plugs and connect it to a obd1 ecu? no obd1 dizzy needed to start?
Cheers
Old Mar 21, 2010 | 05:30 PM
94EG8's Avatar
Seagull Management
You need to run an OBD1 Distributor for it to start, electronics are different (unlike OBD1 and OBD2 B and D-series distributors that are electronically the same) You will also need to run either saturated injectors (read OBD1/OBD2) or install a resistor box if there isn't one already. You could also run a manifold and ECU off an MPFI OBD0 engine and save yourself a lot of work.
Old Mar 22, 2010 | 05:45 AM
Guga's Avatar
If i use obd0 stuff i will need resistor box but wouldnt need distributor, but as i have a complete mpfi obd1 intake mani with all anciliaries and a p08 obd1 ecu, im not going to burn more money in other ecu/mani, and i prefer passing to obd1 as im planning a b swap in the next months, this is just something to get better performance till then.
So i have the obd1 plugs wich im going to hotwire to my ecu plug cables, then i connect the obd1 p08 and install the obd1 distributor with the jumper harness cuz the plugs wont fit, and it starts right?
Just to check.
Cheers and thanks alot for all the help
Old Mar 22, 2010 | 02:46 PM
Guga's Avatar
Just one more question, will the p08 run well in my engine when all its done, even it being from a vtec engine ? As mine isnt vtec...
Cheers guys
Old Mar 23, 2010 | 08:41 AM
Guga's Avatar
help guys plz
Old Mar 23, 2010 | 02:01 PM
94EG8's Avatar
Seagull Management
You've basically got it figured out. The P08 will run a D15B non vtec, but the fuel and timing maps will be off and there will be a CEL for vtec. Find a P06 or whatever the EDM equivelent is if you can.
Old Mar 23, 2010 | 02:13 PM
Guga's Avatar
ialready payed for the p08 so :l screw the cel, it will have no prob right?
Man already got the 0bd1 wired up and the mpfi mani wired and assembled etc!
But when i turn the key the starter turns and it doesnt start up, it like makes explosions spaced by one or two seconds but doesnt start... it started once but very weird idle and died lol ... i havent got the obd1 dizzy so probably its that? My dizzy has obd1 plugs but the car was obd0 so i thought this dizzy would do...
Old Mar 23, 2010 | 03:05 PM
Guga's Avatar
what i have so far:
Where did all these wires came from?
TPS plug cutted to extend wires
D15B intake mani assembled, mutch better looking indeed
another picture of it assembled, still with the injector cables to connect
dpfi injector plugs out
Stuff that got out of the car...plus the obd0 p04
Cheers guys
Old Mar 24, 2010 | 01:22 AM
fourthgenhatchB17's Avatar
Holy crap thats a wiring nightmare at the ecu. Good luck!!
Old Mar 24, 2010 | 02:39 AM
Guga's Avatar
not as bad as it looks eheh
its all wired up except for the o2 sensor wires and vtec wires that im not using, but ithink i have to cut the cilinder position wires and get them to the engine bay likethe 2 new injectors wires did, cuz my distributor must not have the cps in it
Old Mar 24, 2010 | 12:02 PM
Guga's Avatar
my dizzy has gray plugs just like obd1 does, but there are only 5 wires coming to it, and theres another plug, a two wire one, just like in obd1...and its the same shape as the obd1 one....but still the big plug is different than the obd1 one... that must be my problem
Here some pics to see if it clears your mind,and if youcan give me some help in here quoting myself from another topic:
Still have these wires to run to engine compartment, 3 to the 02 sensor, and one i dont know what it is, probably vtec? its the orange with blue stripe lol
My dizzy plug:
The other 2 wire dizzy plug
Anyone knows what these ones plug to? They-re both 2 pin plugs
I have this in the back of my intake mani, theres something missing there, any guess? Is it needed?
Hope you guys can help me, im a bit stuck, gotta get a dizzy, of that im shure, cuz this one only has 5 wires in the main plug as obd1 ones have 7 right?
Have a video of the cars reaction, ill post later to see if you guys can see whats happening.
Old Mar 24, 2010 | 11:57 PM
Guga's Avatar
http://www.youtube.com/watch?v=a1ONQXLwzfI
Old Mar 26, 2010 | 11:27 AM
Guga's Avatar
Cmon guys helppp, do i need the dizzy or mine is ok? It starts now but runs very strange and idle is at 2500, its not OK yet lol still some things to figure out...
Old Mar 26, 2010 | 06:31 PM
Guga's Avatar
forgot to say im gonna keep the p08 cause im gona tune it myself and ill disable vtec when i tune it so no prob
Old Mar 26, 2010 | 08:06 PM
Whats missing on the back of your manifold (which is actually a pic of the throttle body) is where a TPS should be installed.
As for the other 2 plugs , who knows? 1 might be for a sensor/switch thats usually found on the power steering hose??
Old Mar 27, 2010 | 03:45 AM
Guga's Avatar
hm i cant see any connector in the ps hose...
That sensor missing is not the tps, the tps is on top of the throtle body :l
Old Mar 27, 2010 | 08:14 AM
Guga's Avatar
well i checked error codes, i have 9 14 20 21 and 22 LOL
21 and 22 are vtec ones so its normal
14 is IAC
9 is CYP probly cause of the dizzy
Old Mar 27, 2010 | 12:17 PM
Guga's Avatar
Youre right omg sorry.
One of the plugs in unused, it was only used in dpfi...the missing part is the tps, how couldnt i see that piece of metal moved when the trotle plate rotated lol sorry for doubting man.
So the MAP is the thing on top right? I swaped its wires thinking it was the tps omg im so dumb...
Old Mar 27, 2010 | 05:30 PM
Guga's Avatar
tps plug fits the maf? lol wtf
Old Mar 27, 2010 | 10:21 PM
Yes, TPS and MAP plugs are the same.
Old Mar 28, 2010 | 03:02 AM
Guga's Avatar
lol im so dumb i have the tps plug connected to the map lol gotta switch that and get a tps
Old Mar 28, 2010 | 01:52 PM
Guga's Avatar
switched the plugs, map now wired up properly, waiting for the tps and o2 sensor, and the dizzy too, hope that with those parts it runs ok
golf-mk3
Sep 18, 2010 09:43 AM
bbissell05
Jun 20, 2006 12:31 PM
_Endless_
Oct 14, 2004 09:33 PM
averageJoe
Jun 28, 2002 11:23 AM
