The simple 5 lug conversion.
Old Mar 14, 2010 | 10:50 PM
S2Integra's Avatar
Default The simple 5 lug conversion.
I don't know much about why it takes so much for a 5 lug conversion. I underatand that the rear trailing arms and hubs must be from a type-r, therfore rear susp would have to chang along with other essentials. But is all that really necessary? I was looking at oem parts related to the wheel/hub, and I noticed that you can purchase wheel bearing part that includes the lug studs. All you would have to do is take the center nut off, after removing rotors of course, and swap the wheel bearing. It occured to me some time after, that I could simply buy one for a type-r. I don't know anything else about the matter, so I was wondering why cant a 5 lug conversion be done by simply changing the bearing assy to type-r? I only was interested in the idea so as to have a better choice in performance wheels.
Old Mar 15, 2010 | 05:56 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: The simple 5 lug conversion.
you have to change out the whole hub assembly. it can be done. but good luck
Old Mar 15, 2010 | 07:00 AM
unusual71's Avatar
The little spindle that the rear wheel bearing sits on is a different size between 4 and 5 lug pieces if i remember correctly.
Old Mar 15, 2010 | 07:17 AM
I'm not Rick!
the front hubs can be switched out though, ive seen that done.
but like unusual said, idk about the rear.
too bad a 5lug conversion is $1k. if it was cheaper i would prolly buy it too
Old Mar 16, 2010 | 10:37 AM
S2Integra's Avatar
thanks for the feed back everyone.
There are still pretty good choices with 4x100 anyway.
twilliams83
Feb 16, 2010 04:07 PM
radicaled434
Aug 25, 2009 11:18 AM
Toy Civic
Oct 10, 2007 04:09 AM
jordanair45
Jul 1, 2005 02:37 PM
