Speedometer acting weird
Old Mar 16, 2010 | 07:58 AM
KevinEvo's Avatar
Default Speedometer acting weird
I swapped my H23 for an H22. I also swapped the gauge cluster for the H22. When I'm driving, the speedometer will start off about 10km/h too slow. It will gradually fall down more to about 20-30km/h too slow. If I go fast, about 140km/h, the speedometer will read about 40km/h too slow.
If I hold a steady speed on the highway, the needle will eventually go down while I'm holding the same speed. I know it's not reading correctly because I plug my laptop into the ECU and Hondata shows the correct speed.
Also the needle lags when I press the gas or brake. Would a simple recalibration fix this? I tried a few different needles since I had 2 H22 gauge clusters.
The RPM needle is fine. So I switched the needles around and the speedometer still doesn't work, so the needles must be fine.
Old Mar 17, 2010 | 09:13 AM
Mikey3000's Avatar
Default Re: Speedometer acting weird
replace the vehicle speed sensor.
Old Mar 17, 2010 | 07:16 PM
KevinEvo's Avatar
It worked before I switched it. I drove for about a month after the swap with the old cluster. Right after I switched it, I turned the car on and it started doing that. I do have an extra sensor but I doubt it's that.
jfruauff
Dec 30, 2008 06:51 PM
BRIANP
Honda Civic (2001 - 2005)
Jul 4, 2008 09:08 PM
jxhxb
Dec 29, 2007 08:58 PM
gwchndlr
Mar 20, 2007 03:20 PM
candyteggy
Sep 21, 2006 12:21 AM
