Cooling Problem
Old Apr 1, 2010 | 12:38 PM
blackdeath159's Avatar
Default Cooling Problem
So my cooling problem isn't that it overheats, it actually overcools if that makes sense. This is the temperature whenever i am driving down the freeway. This usually happens if i am in 5th gear and not pushing on the gas. It does have thermostat and this picture was taken after driving for 2 hours. I have a D15b vtech engine with stock everything. no a/c and no P/S. The temperature goes up in the streets but once i got on the freeway it went down.
Old Apr 1, 2010 | 01:33 PM
seanbev24's Avatar
Default Re: Cooling Problem
So it has a t-stat, but is the t-stat actually working? Sounds like it failed in the open position to me.
Old Apr 1, 2010 | 01:50 PM
04caddy's Avatar
does it effect performance?
Old Apr 1, 2010 | 02:32 PM
They only affect in performance is that it runs better. my idle is smoother and acceleration feels better but it could just be me. I thought the thermostat was stuck open too but it stays at operating temp during city driving, cold temperature and uphill driving.
Old Apr 1, 2010 | 03:02 PM
dpetro1's Avatar
it still sounds like a thermostat issue. is it an oem honda piece? most local parts stores sell various temp t-stats you may have one thats too cool. so it opens below normal operating temp.
Old Apr 2, 2010 | 11:12 AM
yeah, its the stock thermostat. i replaced it yesterday just in case then i took it for a drive again right after and it still does it.
Old Apr 2, 2010 | 04:56 PM
dpetro1's Avatar
maybe the sensor is bad?? try replacing the 1-wire sensor under the dizzy
Old Apr 2, 2010 | 05:15 PM
clutchrsx's Avatar
when your temperature gauge goes down, do u still have HOT heat?
bleed the cooling system properly after changing tstat?
Old Apr 2, 2010 | 07:48 PM
Holy crap! After driving it and watching the needle go down, i pulled over, popped my hood and my engine and radiator and hoses were warm to touch!!! The only hot part was the exhaust. I think my engine wants a turbo
Wild_Dima
Jan 23, 2012 10:11 PM
401tuner
Jan 31, 2008 03:16 AM
longuyen88
Feb 5, 2007 08:02 AM
selasornayr
13
Dec 15, 2004 11:36 PM
